one seventy front end
rick ky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rick ky Quote  Post ReplyReply Direct Link To This Post Topic: one seventy front end
    Posted: 22 Feb 2023 at 8:35pm
looking for info on changing wide front to narrow
coggonobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2023 at 11:14am
Dr allis did it using a d17 pedestal.  the d17 pedestal is shorter but looks correct, the 170 was the same as a d19
Post Options Post Options   Thanks (0) Thanks(0)   Quote rick ky Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2023 at 5:24pm
will be putting 9.50-15s on front of tractor, hopefully that will take care of some of the height issuses. looking at the spare diesel engine I have, planning on it sliding into position. schmit and sons is going to get me a new mud shield for under the rack and pinion.  Looking for square head bolts for the front weights, and square head bolts for the power assist wheels. make list longer need new bolts for center dish to rear axle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rick ky Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2023 at 12:55pm
what is the length of the studs to connect the wrap around weight to the front of a early 100 series, allis part number 244995. rear wheel square head bolts 3/4"nc x2 1/4", part # 0922394-2. these part numbers are all old numbers, I am sure the numbers have changed. thanks
