Injector washers
cdreb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cdreb Quote  Post ReplyReply Direct Link To This Post Topic: Injector washers
    Posted: 12 Oct 2010 at 6:48am
What is the best way to get the copper sealing washers out from the seat they sit in ? This is on a 3500, 7060 the 190's are easier, but these are bigger diameter and IT book says nothing. Thanks guys
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2010 at 6:49am
They are exactly the SAME part number for 426 and 301 engines.
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2010 at 8:02am
Someone told me to use a 5/8 coarse thread tap.  Put a little down pressure on it and screw it in with your hand, and after you feel it bite, pull it out.  I have only done it once, and it worked like a charm.  Good luck!
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2010 at 11:15am
Ive used and oring pick to get under the ring and pry it up.  The 5/8 tap sounds like a good idea too.
