6080 Transmission
rbaggett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rbaggett Quote  Post ReplyReply Direct Link To This Post Topic: 6080 Transmission
    Posted: 21 Jan 2023 at 12:06am
I have an 1982 6080 that used to shift easily but now is a bit stiffer to shift and if it gets in a bind like when driving through sand or pushing a bale fork into a group a round hay I can't get it out of gear on the gear shift and the range shifter.  I tried backing off the clutch a little but that had no effect.  Any ideas why this happens and how to fix it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2023 at 6:13am
If it is only a problem getting out of gear, shut off the engine and if it then comes out of gear more easily, it is the clutch dragging.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2023 at 6:34am
I have stuck a WD 40 straw into the top of the shifter boots and sprayed lube on the shifter mechanisum- helped a bunch on mine
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2023 at 8:04am
2wd or 4wd?                  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote rbaggett Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2023 at 8:22am
It will not come out whether the engine is on or off.  I have to move the tractor forward until I can pull the transmission lever out of gear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rbaggett Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2023 at 8:25am
It will not come out of gear whether running or not. I have to move the tractor until I can get it to come out
Post Options Post Options   Thanks (0) Thanks(0)   Quote rbaggett Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2023 at 8:26am
It is 2 wheel drive
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2023 at 8:35pm
Are you sure it is full of oil? (check plug on right side of transmission ) Have saw shift rails gaul from lack of oil.                    MACK
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2023 at 8:49pm
Is everything right with the clutch?
Crank end play?
Edited by victoryallis - 21 Jan 2023 at 8:49pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2023 at 10:00pm
Mack has a very good point. Where are you checking the transmission oil ??
Orangeisgreat190 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orangeisgreat190 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2023 at 4:50am
Check the clutch cable that actuates it.  A friend of mine had a similar issue.  The clutch cable had stretched enough that it would not take enough pressure off of gears to shift easily.  Worth a shot.  Hope this helps.
