D14 Rear Rims |
Post Reply ![]() |
rjranch ![]() Bronze Level ![]() Joined: 14 Sep 2009 Location: Nebraska Points: 32 |
![]() ![]() ![]() ![]() ![]() Posted: 19 Jan 2023 at 2:05pm |
Looking for suggestions to what combine rim will work on a D14. I do not need to spin out for the tractors uses and would like to go with a 28" rim since used tires in 28" are easier to find. Anyone have a suggestion?
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7495 |
26" Rims are more common than 28s, but they use a bigger tire. Keep in
mind, combine rims stick out wider than the power adjust rims. They
will not sit close to the fender. These are 18.4 x 26 combine rims on my D17: Same tractor with power adjust rims: |
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24645 |
probably any that are 26" with 8by8 bolt pattern..... I've got a mix of spinout(power adjust) and combine on my 3 D-14s.
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 87573 |
as Myron said, most combines are 26 inch and WIDE...
What you want is a 28 inch rim about 12 inches wide with an 8 bolt pattern ??? your probably talking about something like this, with an adaptor plate to 8 bolt axle Edited by steve(ill) - 19 Jan 2023 at 3:51pm |
tractorboy ![]() Silver Level ![]() Joined: 03 Oct 2009 Location: southern Va Points: 474 |
I once owned a 14 that someone had changed rear rims , can't remember what size but they were taller than original . I didn't like them cause they changed the gear ratio, seemed a little short on power but I could walk away from 'em on the tractor rides !!
![]() keith so. va.
i think original tires on the D14 were 12 x 26 ........... if you get combine tires they would be 14.9 or 16.9 x 26 ... so taller ........... if you go to a 28 inch rim, i would stick with 12.4 tires to keep the height within a couple inches of original.
Edited by steve(ill) - 20 Jan 2023 at 8:15am |
For a combine 16.9 x 26 and 18.4 x 26 would be most common.
I have 3 D14s. None of them have 12.4 x 26. Those would be tiny in my opinion. 13.6 x 26 seems pretty common on a 14. I am running 14.9 x 26 on all of mine. |
Post Reply ![]() |
