Why do some diesels require ether and some dont?? |
Page 12> |
| Author | ||
bigcreek
Joined: 08 Sep 2016 Location: Weiser, ID Points: 43 |
Topic: Why do some diesels require ether and some dont??Posted: 18 Jan 2023 at 11:37pm |
Hopefully this post doesnt get thrown in the fire since it doesnt have to do with an AC machine but if so I understand. So it is obvious from the title of this thread I am not the worlds greatest mechanic or Id likely know the answer to this question but.. I have various diesels from pickups, tractors, welder/generator that are diesel and fire right up even when it is freezing cold WITHOUT ether. However I have a Case forklift with a Cummins 4 cylinder engine that will not start at all unless it gets a shot of ether. It is a strong running engine, but wont start without it. What possible causes could make this machine not start without its shot of ether? Thank you in advance.
| Sponsored Links | ||
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54678 |
Posted: 19 Jan 2023 at 4:48am |
I'd check injection timing, compression and fuel filters, in no preference of order. Also remember that American made engines generally have thicker piston tops, and can withstand the ether hammer effect, but Asian diesels should never get ether...
![]() Also, if you can check the pre-heater, some engines have it, some don't, some have 1 and its not connected. I use a Coleman tent heater, slide it under the motor, and let it heat the motor for about 45 minutes, and most any engine in good repair starts right up... (Do not use this technique on an oil leaker, though!
victoryallis
Joined: 15 Apr 2010 Location: Ludington mi Points: 2879 |
Posted: 19 Jan 2023 at 4:50am |
Must be something wrong with it the 3 Cummins we got all start good some below 32. Timing off????? Compression must play into it I have I 6080 that if it was below 50 you were screwed put the 16:1 kit in it and starts great to upper 20’s
fjdrill
Silver Level Access
Posted: 19 Jan 2023 at 7:47am |
Old Timers said if ever start using ether on an engine. it would need it like crack. I found the old 855's liked just a small whiff & Perkins hated it.
DrAllis
Posted: 19 Jan 2023 at 7:54am |
In order for any diesel engine to fire up on a cold start, there has to be enough heat built up in the combustion chamber to ignite the cold diesel fuel that gets squirted into it. An engine with 17 to 1 compression ratio will start better than one that is 16 to 1 or 15 to 1 or 14 to 1. The heat is made by the compressing of the cold air on each compression stroke. So, faster cranking speeds helps, higher compression ratios help, injection pump timing closer to TDC instead of BTDC helps, some sort of electric coolant heater helps, an intake manifold heater helps, combustion chamber glow plugs help, etc, etc. A hard starter when cold doesn't automatically mean there is something wrong with the engine, because some engines are just naturally better at cold starts than others. In this particular application, maybe there are hydraulic pumps that are keeping the starter from its best possible cranking speed ?? Maybe your battery needs to be two batteries?? and not cheap batteries either. More CCA's the better. Maybe your starter needs freshening up ?? But, not saying inj pump timing couldn't be off, I'm saying pump timing doesn't CHANGE itself. So, I doubt that it is the problem, if there is a problem. My Dad always plugged in his chore tractor to be sure it would start when needed. Kind of like Marshall Dillon tying his horse up when he got out of the saddle.
Edited by DrAllis - 19 Jan 2023 at 8:06am |
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 34847 |
Posted: 19 Jan 2023 at 7:57am |
Are generally a combination of mechanical faults that demand Ether. Low Compression, indicated by serious blowby, valve lash or camshaft lobe wear reduces ability for engine to breath and release combustion gases, valves not seating refer to low compression, nozzles tips eroded, and they do that over time regardless fuel quality where do not positively atomize the fuel to combust.
My 180 has two of these, rings are getting weak or cylinders just glazed horribly with notable blowby, have had pump rebuilt where once running has plenty of power but I can smell the unburned fuel from the exhaust tells me nozzles need to come OUT. Old gal needs a freshen overhaul about as much as I do!!
MACK
Posted: 19 Jan 2023 at 7:58am |
There are alot of things that go into a diesel to start. It has to have compression to start. Cylinder temp. has to get to some where around 800 degrees for the diesel fuel to ignite. Cam timing, cam design, inj timing, pump, cranking speed, air temp, and many other factors that effect a diesel to start. MACK
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12320 |
Posted: 19 Jan 2023 at 8:09am |
Every chore tractor we've ever had of any color has a block heater that's on a Christmas tree light timer. It's set to be on for about 4 hours, 2pm - 6pm. It's just sooooo much nicer to hit the key and go easily. If I need it at a different time, can set another on period, or simply turn the switch on. Even 20 minutes helps some, rarely need it in a more urgent emergency than that. If I do, well, there's some I own start better than others. One tractor in particular has a unloading valve for the hydraulics that helps a bunch.
DMiller
Posted: 19 Jan 2023 at 8:16am |
Anything below 40 my 180 is set up that way. Timer was for old incandescent lighting so can carry the amps.
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24866 |
Posted: 19 Jan 2023 at 8:38am |
My BUDA BD153 in the forklift needs 3 short squirts of ether to start it AND 2 good batteries to spin. OK, it has so much 'blowby', I've rigged ABS plumbing to 'recycle' the fumes from the oil filler cap to the intake. yes, I KNOW it has low compression but the 5K estimate is a LOT more than a few cans of ether ! I was told years ago that Freightliner trucks do NOT have glowplugs or intake heaters, just turn the key and start them up.....
Tbone95
Posted: 19 Jan 2023 at 8:47am |
Yep, mine easily handles the correct amps, been using it for years. I start using mine when around 30 or less, depending.
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3122 |
Posted: 19 Jan 2023 at 9:15am |
Not a mechanic but I've found a strong high CCA battery is key to starting a diesel.I'll also hook a jump box on the battery too sometimes.That said I had a David Brown built Oliver 500 years ago that had to have a small snort of ether to get to fire up regardless.Then it ran just fine.
TomC
Joined: 24 Nov 2017 Location: Hillsboro, MO Points: 1549 |
Posted: 19 Jan 2023 at 9:23am |
My Yanmar has a thermocoupler and compression release it starts at any temperature I have never used ether on it,I have owned two 7.3 and two 6.0 navistars they all had block heaters and glow plugs so as long as they were plugged in they started at any temperature , I've had Cats, Cummins and Detroit's they all had block heaters but if it was going to get into the single digits I'd turn them up to about 1,100 and let them run.Years ago I had a Cummins 335 that had a compression release and a little compartment with a lid on it,you dropped what they called an ether egg in it when you closed the lid it punctured the ether egg giving it a pre measured shot of ether,that system wasn't around that long. The long and short?? Want to tear up a diesel and severely shorten the life of a diesel?? Use ether.
darrel in ND
Joined: 22 Nov 2009 Location: Hebron, ND Points: 8754 |
Posted: 19 Jan 2023 at 2:50pm |
Nothing good ever comes of using ether
Darrel |
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3544 |
Posted: 19 Jan 2023 at 4:25pm |
Years ago we had 2 185's on the lot. One would crank before the finger could be released from the button. The other would not crank w/o ether and or air heater on a cool day. We said YES we will find the secret to cranking. We swapped starters, batteries, battery cables, injectors and even the fuel pump from one to the other - the one that would start would start all the time the other - nada... we checked compression - the one that would start actually had a tad less compression than the non starter. We checked valve setting, timing again - nothing we could do would make one start as easy as the other. We were running up a big bill when we thought about checking valve timing - the cranking one had valve timing that was about 2 degrees (non scientific measurement) sooner - didn't dig into why as we had one sold, but that was the only thing we found different, why or how we do not know. Go figure ...
PS the latest 2800's with the bosch injectors and last timing advance program would CRANK... and sounded different, and didn't smoke..
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5146 |
Thanks(1)
Posted: 19 Jan 2023 at 5:33pm |
Compact Indirect injection diesel eninges like kubotas, or yanmars, or AC 5020's for example, run very high compression ratios in the 22:1 range, and do not like ether, there's too many nooks and crannies with the precombustion chambers that causes issues with the ether. Those engines will typically have glow plugs that need to be used when starting the first time of the day, even in the summer. Never use ether if glow plugs have been heated up!
TramwayGuy
Joined: 19 Jan 2010 Location: Northern NY Points: 11799 |
Posted: 19 Jan 2023 at 5:37pm |
It also helps a lot if you use 0W-30 or 5W-30 synthetic in winter!! Cranking speed is important.
And direct injection is a huge advantage. |
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8729 |
Posted: 19 Jan 2023 at 8:04pm |
And any electronic (modern) diesel will cold start way below what the older mechanical engines will....there's probably a few exceptions to that....
bigcreek
Posted: 19 Jan 2023 at 8:06pm |
Lots of good information here guys I appreciate it. Ive got a good diesel mechanic coming over soon for something else so Im going to talk to him about this Case and see what he thinks he can or cant do with it. The block heater doesnt work on it so I do need to replace that. One other thing this lift has is a factory installed thing a ma jig that you screw a canister of ether into and it gives the motor a shot of ether when starting. I know its factory because it shows it in the owners manual. So apparently the company thought some ether with this motor was ok. But Id best swap out that block heater and start plugging it in. I just put a new group 31 battery in it last week. Got it from batteries and bulbs and told them give me the best group 31 you have so cranking amps are good.
Les Kerf
Posted: 19 Jan 2023 at 9:08pm |
I grew up running old Cats, my Dad had a D2 and a D4, both equipped with pony motors. I still have the owner's manual for the D2, the official starting procedure was to start the pony motor, let it warm up enough to crank the diesel, then spin the diesel with the compression released and no fuel until the pony motor had warmed up the diesel engine (they shared the same cooling system) then hit the compression for a while, and then finally hit the fuel to start the diesel. I actually did this one warm spring day, it required a full 45 minutes of cranking under compression with that pony motor running wide open before it would start. Or, get the diesel spinning, hit the compression followed immediately by fuel then give it a quick snort of ether, followed by instant noise ![]() Whenever possible my Dad would park the D2 on a hill with the blade chained up. Get it rolling downhill, give it a snort of ether and yank the clutch back, that thing wouldn't make more than two revolutions and it was running. My Son-in-law's HD5G came factory equipped with the ether pill starting aid, and I know that some fairly new Caterpillar stuff has ether starting aids as well, so it must not be all bad. |
Les Kerf
Posted: 19 Jan 2023 at 9:12pm |
Yup, when the factory installs an ether thing a ma jig you can pretty much count on hard starting ![]() |
im4racin
Joined: 12 Jun 2017 Location: Garrison ND Points: 1082 |
Posted: 19 Jan 2023 at 9:14pm |
Either won’t hurt direct injected diesels when used sparingly. The problem is when it is over used and that is what breaks rings and skirts.
That being said…I have drove compact construction(idi with glow plugs) equipment across the lot on either when it was gelled up and it didn’t seem to hurt it! But wouldn’t recommend it!
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5083 |
Posted: 19 Jan 2023 at 9:37pm |
One of the things no one has spoken about is the starting fluid. I don't know why, but when I do have to use starting fluid, I find John Deere starting fluid is much better than any other brand. Am I getting senile or is there a difference?
Les Kerf
Posted: 19 Jan 2023 at 9:42pm |
No doubt it is better but I am a tightwad and buy the cheapo Walmart stuff. A can of it lasts a long time. |
jvin248
Posted: 19 Jan 2023 at 9:59pm |
. Engine spin. Good battery, thick battery cables, clean contacts, dielectric grease after cleaning, good switch. .
bigcreek
Posted: 19 Jan 2023 at 10:39pm |
When I put the new battery in it I cut an inch off the ends of the cables at the battery end due to corrosion and put new clamps on that end. This forklift is a mid to late 80's and was city owned. It sat for several years before they auctioned it off. They didnt say how many years it sat for only that it sat for several years. I changed all fluids and filters. The battery was a junkyard battery they put in it just to get it from the city lot to the auction yard. Anyway one thing I havent looked at is the other ends of the cables at the starter and ground. Ill take those ends off and give them a good cleaning. Great running forklift otherwise. My other forklift is an 1980 ACP60 Allis Chalmers and a dang fine one at that. Gas though.
SteveM C/IL
Posted: 19 Jan 2023 at 11:27pm |
I believe JD juice is"higher strenght" than most others. Think it has been discussed here before.
Gary Burnett
Posted: 20 Jan 2023 at 5:49am |
Wonder if that is a good thing?Seems to me the more potent the ether the more damage it could do to a motor.
corbinstein
Posted: 20 Jan 2023 at 6:13am |
JD juice is designed to make you buy more of that expensive green paint.
DrAllis
Thanks(1)
Posted: 20 Jan 2023 at 6:15am |
John Deere starting fluid is 80% ether and is thee only thing serious tractor pullers will use to get their de-compressed and overfueled diesel engines to start when cold. A lot of other starting fluids are far less than 80% and won't ever start a pulling engine, so yes, cheap ether is probably less likely to do damage on a good engine, IF it gets the job dun.
Page 12> |
