160 LH tie rod end |
Pafarmer92
Joined: 15 Jan 2023 Location: Connellsville Points: 2 |
Topic: 160 LH tie rod endPosted: 15 Jan 2023 at 2:24pm |
Hello I’m looking for a left hand tie rod end for my standard ac 160 I understand they are no where to be found however I’ve heard of guys who have used one from a parts store and welded it to the old tie rod after going to a couple parts stores they are no help as to finding a tie rod end close to the size I need I was wondering if anyone on here had suggestions on one that might work thanks.
Mikez
Posted: 15 Jan 2023 at 5:22pm |
Might be able to help you. Let me do some digging for part numbers
Edited by Mikez - 15 Jan 2023 at 5:46pm |
pump grump
Bronze Level Access
Joined: 11 Mar 2012 Location: dayton oregon Points: 31 |
Posted: 15 Jan 2023 at 8:22pm |
I`ve got mine from AGCO .
MACK
Posted: 15 Jan 2023 at 8:24pm |
Most parts people today only know what that screen in front of them tell them. MACK
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90812 |
Posted: 15 Jan 2023 at 9:06pm |
if your going to do it yourself, your going to need to figure out the thread diameter and thread pitch , and left hand thread... then cross reference on a chart.. Is it METRIC or ENGLISH thread.. etc.
Mikez
Posted: 15 Jan 2023 at 9:23pm |
Which front axle do you have
acjwb
Posted: 15 Jan 2023 at 10:15pm |
I replaced two a couple months ago. I had to go to two different auto parts stores to finally get them. The parts boy and I went back and just started comparing them till we found one that would work. I took my old one with me. The one I used was Duralast FA2101. I got mine from Autozone but can be crossed to other brands. I also saw it online. My tractor has power steering and the model is spelled out "one sixty" Hope this helps. Might pick one up at local store and make sure it fits yours.
Alvin M
Posted: 16 Jan 2023 at 5:36am |
I use Case IH part # K207722 cut old one off drill hole weld in or tap threads I did 12 that way
Mikez
Posted: 16 Jan 2023 at 4:57pm |
72074176 is the wrong one ha. For different style front end.
