190XT Starter
Gary (sw Wis.) View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary (sw Wis.) Quote  Post ReplyReply Direct Link To This Post Topic: 190XT Starter
    Posted: 14 Jan 2023 at 4:10pm
Is there a trick to getting the starter out without taking the fuel line apart?
190XT - D17 - D14 - WD45 w/loader - WD - (2)B110 - 616H - 610 - B-208 - WD with 190 Mounted Corn Picker - All Crop 60
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2023 at 6:33pm
Shut the fuel off at both of the sediment bowls. Take the inlet line loose at the primer pump and also loosen the line at the fuel filter base that comes from the primer. Remove the one bolt that's secures the primer assembly and just set the whole thing aside. Put the bolt back in if it leaks a little antifreeze. Plenty of room then for the starter removal.
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary (sw Wis.) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2023 at 7:46am
Thanks Lynn, That what I thought, I was hoping to avoid removing thr primer.
NDBirdman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NDBirdman Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2023 at 9:20pm
I had to remove my primer to remove the starter.
