7060 Blow by tube mount |
AC 426 power
Topic: 7060 Blow by tube mountPosted: 11 Jan 2023 at 7:24pm |
I removed the blow tube mount at the bottom of the engine a couple of years ago when I rebuilt the engine and apparently I forgot to install it, tube was in place just no bottom mount and now I can’t remember how it goes on, can’t seem to find anyplace in the area that would take a bolt to mount it, any pics or explanation would be helpful, thanks!
DrAllis
Posted: 11 Jan 2023 at 7:31pm |
One of the oil pan bolts.
MikeKroupa
Bronze Level Access
Joined: 12 Sep 2009 Location: pierce,nebraska Points: 77 |
Posted: 11 Jan 2023 at 7:41pm |
It bolts to the bottom side of the oil pan, you just need to remove the corresponding bolts and reattach. The round hose clamp will then be parallel with the bottom of the engine block, slide the vent hose through and all will be good.
Ron(AB)
I can check my 7050, maybe get a pic.
405, 7000, 7050, 8050, 8070, L3, 2300 & 2600 disk
AC 426 power
Posted: 11 Jan 2023 at 8:07pm |
Alrighty makes sense, thanks for the replies!
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2483 |
Posted: 11 Jan 2023 at 8:21pm |
You'll be able to tell by the lack of paint on the pan rail.
