6080 2wd tie rod end |
977.3Ford
Joined: 04 Oct 2019 Location: Dayton, Ohio Points: 103 |
Topic: 6080 2wd tie rod endPosted: 09 Jan 2023 at 12:32pm |
Having problems finding the right hand tie rod end for our 2wd 6080. Agco part number is 70260801, the number is obsolete and my dealer couldn't cross it over to anything else. It looks like the 6060/6070 share a rod end with a 170/175, but nothing for a 6080. Is there a tie rod out there that will work or am i on my own to make a replacement?
Jimmy
1982 8050 Powershift 1982 6080 1992 R52 Gleaner |
ac160
Posted: 09 Jan 2023 at 1:11pm |
Have you tried 70260802? It appears to be the full tie rod with both ends. Also check with some of the sponsors on here. Mcmaster carr seems to have some tie rod ends, but not sure if they will work. I know some of them can get some hard to find items. I am curious what you find out. I have a couple of 2wd 6080s as well, but haven't had to change the tie rod ends yet.
Albert
Posted: 09 Jan 2023 at 10:21pm |
70260802 is no longer serviced by AGCO. I have been looking for a replacement on and off for two years with no luck. If you find please post so we can help others. It is also used on the 7000 with light axle. I had thought of moving cylinder to the left and welding brackets to the tube like the 7000 series did.
Albert
jrjuday
Joined: 12 Sep 2009 Location: n.e. indiana Points: 119 |
Posted: 01 Aug 2024 at 11:55am |
Has anyone been able to find these tie rod ends?
Alvin M
Posted: 01 Aug 2024 at 4:50pm |
I have 21 of 70260801 tie rod ends I got made 295.00 plus shipping
jrjuday
Posted: 01 Aug 2024 at 9:19pm |
Where are you located?
jrjuday
Posted: 01 Aug 2024 at 9:41pm |
Can I send you a PM?
Alvin M
Posted: 02 Aug 2024 at 6:31am |
Yes u can New Holland PA
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3102 |
Posted: 02 Aug 2024 at 7:01am |
Aren't they basically a Fiat except for the motor? might try looking at Oliver 1365 ends.
DrAllis
Posted: 02 Aug 2024 at 7:21am |
Front axle was all A-C.
Mikez
Posted: 02 Aug 2024 at 7:43am |
Curious where you had them made
