8070ps
BStone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BStone Quote  Post ReplyReply Direct Link To This Post Topic: 8070ps
    Posted: 08 Oct 2010 at 7:23am
I assume the input shaft seal is leaking...hyd oil leaking out the bell housing after running a couple of hrs.But the low pressure trans light started coming on after a couple of hrs also when the leak occurred.Trans still pulls fine.I know someone said it could be a wire grounding out or a bad a switch but isn't it odd it only started happening when the seal started leadking? I'm going to get it in the shop next week and start on it.What else should I be checking? Thanks for any replies.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BStone Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2010 at 3:32pm
bump
