WD-45 turbo kit
Carl(NWWI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Topic: WD-45 turbo kit
    Posted: 06 Oct 2010 at 9:27pm
Ok, whos gunna be the first one to try it. I know i wanna. spendy i bet.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2010 at 9:46pm
I saw one at the Orange Spectacular this past summer, but it did not look that neat!
OrangeFever View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangeFever Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2010 at 9:50pm
Neat find anybody know the cost. Does anyone make a custom manifold without the turbo to replace stock one?
firebrick43 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote firebrick43 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2010 at 12:24am
hard copper oil return line looks hooky and liable to crack at the worst time.
Also will an allis oil pump keep enough oil to a turbo?
I have seen these guys with an M in farmworld.  I want to say it was 1500 plus for the kit but its been a while.
Chris(WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris(WA) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2010 at 6:07am
I see the air cleaner is not connected. Is the oil bath cleaner too small to support the increased air volumes of a turboed engine?
 Hate to build that kind of power then suck dirt thru it all day!
Washingtonian by choice, Wisconsin Farmboy by the grace of God!
Good View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Good Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2010 at 6:52am
I want one!
B212,716,two 314H's,WC,WD,D19,190XT
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2010 at 7:10am
from extensive cylinder head flow testing . it is my opinion that the 226 engine at 7psi of boost would really respond in a hp increase . i would think the carb at 7psi of boost would need to be larger and the ignition would also need upgrade.
Edited by mlpankey - 07 Oct 2010 at 7:12am
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2010 at 8:04am
My thoughts exactly. I know a guy that has a Keystone setup on a Farmall M. He just bolted it on, didnt change card or ign. It sure helped, could wake it up more if he would have did a few more upgrades
1968 D15D,1962 D19D
Pa.Pete View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pa.Pete Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2010 at 8:44am
Looks like fun.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2010 at 9:10am
I have been kicking around installing a efi fuel system on a puller . just so I would be the first with a lap top hooked to a antique tractor. Could you imagine turbo and efi.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2010 at 9:53am
It says that it will work on a WC. I want one. It would make all the JD fans that tell me the JD 2cyl is better than the AC 4cyl think twice!!
I wonder how much of a power boost it would give a WC.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2010 at 10:09am
Going by the chart, you could get 109 hp out of it. But my math may be wrong....
Edited by Charlie175 - 07 Oct 2010 at 10:10am
Charlie
ALinIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALinIL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2010 at 10:24am
I have seen one on a IH M.  The performance was NOT impressive.  This was at a couple of antique pulls.  I would be concerned with the fuel puddling in the intake pipe between the carb and the turbo.  Just my 2cents. - AL
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2010 at 12:27pm
I would think the 7 psi would keep the puddles down . your hp output is right on with a 85%ve
Edited by mlpankey - 07 Oct 2010 at 12:43pm
Good View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Good Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2010 at 1:50pm
Should be able to put on D17,170,175 and E combine for those who want to pick a little faster.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2010 at 6:53pm
I'd be leary of putting one of those on a tractor and then plowing all day with it. Might run good and hard for a while, but long term usage I'd be wondering what would happen even if there was enough radiator to keep the coolant under control.
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2010 at 6:57pm
 Or the normal oil pressure of 7 psi in those engines?
smuggler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smuggler Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2010 at 7:47pm
I would have to say 1500 would be cheap  thats a pretty sweet manifold. And i bet not cheap but still looks nice.
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2010 at 8:28pm
  have a freind with one on a D-17    been on for years 5-6 i know of
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2010 at 9:50pm
Norm, does he use it for heavy long term use like plowing?
TexasAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TexasAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2010 at 7:18am
I would think a higher rate of flow and not pressure would be a more critical factor for turbo oil.  Same principle as high volume low pressure hydros.
Good View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Good Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2010 at 9:29am
They make it sound like the M is reliable.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2010 at 11:41am
I'm just wondering if the valves/pistons could handle the extra heat of running under 7psi boost, using all of that extra available power for an extended amount of time. Isn't the term brake mean effective pressure? The best example of exceeding BMEP is the super stockers that shoot colums of smoke 100+ ft in the air.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2010 at 12:24pm
I know more than a few people with M's and haven't had issues with them and these are old time farmers.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2010 at 1:58pm
 Well , if one good, two should be more better. Twin turbo's and an intercooler, maybe a whiff of NOS, and on it go's
KY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KY Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2010 at 3:03pm
I dont know how the trans, clutch, hand clutch, and diff in those tractors would handle that kinda horse
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALinIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2010 at 4:25pm
Guys - I don't think you are going to break anything by adding the charger.  You may shorten the power train life.  The most you may see from this setup is a 20-25% increase in HP.  Sound like a lot, but in reality 7-10 HP.  This is a gas engine not a diesel.  - AL
Post Options Post Options   Thanks (0) Thanks(0)   Quote smuggler Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2010 at 6:59pm
The Theroy on are tractor with multiple turbos is not to build more boost presure. Its to increase volume of air we dont run alot of boost a touch bit more than 7 psi but not near what a diesel super stock runs. Also dont forget the harder u squeeze the air the hotter it gets. I cant beleve 7psi makes a tremendous amount of heat.
Unstylish View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unstylish Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2010 at 9:19pm
Sorry Mitch, but we already got you beat up here in Michigan..MSD PN 8979.. :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2010 at 6:26am
mapping ignition is allright but i want to map fuel curve etc.
