WF rear wheel centers ? pics
TomMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Topic: WF rear wheel centers ? pics
    Posted: 06 Oct 2010 at 6:31pm
Were the WF rear wheel centers all different than the WC or is this difference just because my WC is a 1944 and the WF is a 1950.  The casting numbers have a different dash number.  The WC casting number is AM-3082-8 and the WF is AM-3082-18 (could be -10 I couldn't see it very well).
The difference is easy to see, the gap between the rim and the hub between the wedges is much wider on the WF.  One can easily slide their fingers through but on the WC there is very little gap.  Also the dimples on either side of the valve stem are quite large.  Does someone have a late WC with centers like the WF or an earlier WF with centers like the WC?
WF:
WC:
Thanks
Tom
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2010 at 7:30pm
I have a 49 WF and 47 WC, the rims are the same as yours.
Jim in SE ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim in SE ND Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2010 at 8:45pm
I haven't noticed the difference on my 49 WF, will look tomorrow to see just what mine are.
Henry se/k! View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Henry se/k! Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2010 at 9:01pm
The 1949 wf that I have has one piece steel rims.and wheels. Think they are correct for this tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2010 at 9:07pm
I thought the one piece wheels were from 1937-1939 WC's.?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2010 at 12:12am
The one peice stamped steel rim was used on wf  # 204 - 1903 and all wf industrials.  I will see what rear wheels are on my wf tomorrow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2010 at 5:40am
Now that you mention it I do remember reading that some of the unstyled had them. I don't think I've seen an Industrial WF.
Chris(WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris(WA) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2010 at 5:55am
My 1948 WF has one piece steel rims too. My 1948 WD has two piece wheels like the second set. The one piece are 24" and the two piece are 28".
Washingtonian by choice, Wisconsin Farmboy by the grace of God!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Henry se/k! Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2010 at 6:15am
Now guys, you have me wondering, what makes an inderestial besides tire size?
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2010 at 7:30am
Chris all WD's should have power shift wheels . The solid cast centers Tom shows have 6 hole centers, the WD has 8 hole axle flange no way they would fit unless adapter was used.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2010 at 9:02am
So it looks like no WC's ever had the rear center like my WF, but it may just be an updated center after the WC was no longer being made.  The parts book I have is for WC and WF and it doesn't show any different centers for the cast hub like this.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim in SE ND Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2010 at 9:17am
I looked at my 49 WF, has same centers as yours, never looked that close before, just a thought, maybe when the WC ended they changed because they didn't need near as many and maybe an outside supplier.
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2010 at 10:22am
My WF has the cast hubs as your pic.  There are 5 WF's at the local wrecking yard and they all have the same cast hubs except for one which has 24" one piece steel rims. I always thought they were combine wheels. ???
R Aiken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2010 at 11:09am
My 47 WC has wheels like the top picture and my 39 WC has wheels like the lower picture.
This page was generated in 0.258 seconds.
