Tire chain measurements
littlemarv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Topic: Tire chain measurements
    Posted: 16 Oct 2022 at 5:50pm
Anyone know what size chains fit a 13.6 by 28 tire? I see a lot of ads where they only have the measurements of the chains, for instance "set of chains, measures 18" by 10 feet".
Thanks in advance.
The mechanic always wins.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2022 at 5:58am
I'm pretty sure I told you on Facebook, but I'll say it here for anyone else.  Look up the Laclede Chain web site.  They are the only place I've found to give dimensions for their chains.
AaronSEIA
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2022 at 7:11am
Measure the diameter of your tire and multiply by 3.14. That will give you the circumference (length around the tire). As long as they are wider than the tire, they should drop down the sidewall, thusly shortening the length needed to connect the ends.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2022 at 8:12am
as trucker said, your tire should be about 52 inches in diameter, so the circumference is 52 x 3.14 .... or 163 inches around , which is 13.6 ft.
If your chains are 18 inches wide so that they drop 3 inches down on the sidewall on each side, then the tire diameter would be  52 - 6 or 46 inches..... that would be 46 x 3.14 or  144 inches long , which is 12 ft  long chain.
Edited by steve(ill) - 17 Oct 2022 at 8:16am
This page was generated in 0.116 seconds.
