180 Diesel Clicking Noise
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Topic: 180 Diesel Clicking Noise
    Posted: 09 Oct 2022 at 9:54pm
Our 180 diesel has started making a clicking noise when the key is turned on.  This continues when the tractor is started and running.  It sounds like it is coming from the fuel tank area.  Is this something to do with the fuel pump or something else?  How can it be remedied?  Thanks, Dave
Do not argue with an idiot. He will drag you down to his level and beat you with experience. Mark Twain.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2022 at 6:00am
Voltage regulator under the instrument panel hood.
allisorange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisorange Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2022 at 6:30am
I agree with the Dr. That where the regulator is.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2022 at 7:59am
Ground wire is unhooked on voltage regulatory.                  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2022 at 8:23am
Thanks for the info.  We did have the hood off a few months ago to clean out a mouse nest and mess.  Must be some damage left over from the damn mice!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2022 at 9:44am
Checked and the ground wire was securely connected.  So, bought and installed a new voltage regulator.  Now, when the key is turned on, the voltage regulator makes a buzzing noise.  I believe we connected all of the wires correctly, but don't know why it is buzzing.  It still does this when the tractor is running.  Also, what exactly does the voltage regulator do, as it appears the system is charging when the tractor is running.  Thanks, Dave
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2022 at 10:51am
Regulator needs to be correctly hooked up.
F terminal on regulator goes down to alternator F terminal.  Check field wire for possible ground or open/short or poor connection from some previous circumstance.
Terminal 2 of regulator goes to a connector under the dash that goes to the B terminal on key switch. from same connector that will lead up to the fuse that is used for temp, fuel gauge and oil pressure idiot light. check for poor connections or grounds on that wire.
 This wire turns on and off the regulator's internal switch that supplies power to alternator F terminal.
Terminal 3 on regulator is connected to wire that runs through the wiring harness and eventually gets to the starter solenoid's 'B' battery terminal. That wire carries the amount of voltage to the regulator and the power  to operate the charging system.
Regulator my have a slight hum, but if it is an electronic regulator (non mechanical internals) it should not hum at all.  Regulator needs to have good ground, and hood needs good grounding.
 To check if alternator is charging good, can disconnect harness at regulator and jump connections 1 and 3 on wiring harness connectors and should have something like 32 output amps.
  May have alternator internal troubles... like brushes worn out or ...broken wire inside or short ...
  Good Luck.
This page was generated in 0.191 seconds.
