WD Engine - Main Bearing Caps Matching
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Topic: WD Engine - Main Bearing Caps Matching
    Posted: 09 Oct 2022 at 11:58am
On a WD (and I assume at least WC as well), do you need to keep the main bearing caps that were original to the block, with that specific block? Or, can you swap main bearing caps from one block to another without any issues?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2022 at 12:40pm
Would be best to keep original.. If you HAVE to change out, i would bolt the cap on empty and check for any LIP or overlap at the mating surfaces... You may have to mix and match to get a better FIT.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2022 at 2:19pm
If someone gives you a WC/WD block without main caps, it's too expensive to line-bore it even if you had main caps from another block. I'm just sayin......
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2022 at 3:07pm
Got it - avoid mixing caps and blocks if they didn't come together from the factory. Thanks guys.
den/southern illinoi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2022 at 4:55pm
I know I always keep the caps in the same location as they were.  Den
Own 4 wheel 20, 5020 and associated equipment and 1 electric forklift. Also a 720 garden tractor, 720 Diesel. 620 and soon a 616 garden tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2022 at 6:09pm
If you switch caps with another motor, it is POSSIBLE that the bore in the cap and the bock could be miss matched by .005 inch.. and you would have bearing interference with the crank when you install... of course it could be miss matched .001 and would probably work...... Thats why it is not a good idea to mix and match.. but if you dont have the original caps, you need to check the alignment of the two half bores and make sure the offset is very minimal.
exaggerated it could look like this...
Edited by steve(ill) - 09 Oct 2022 at 6:15pm
