Subsoiler
james6600 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote james6600 Quote  Post ReplyReply Direct Link To This Post Topic: Subsoiler
    Posted: 05 Oct 2022 at 6:21am
Will this fit on a WD45 that has the snap coupler hitch with the bell for the drawbar.
only AC orange View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote only AC orange Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2022 at 6:26am
No, that is for WD pin style hitch!
Post Options Post Options   Thanks (0) Thanks(0)   Quote james6600 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2022 at 6:36am
Since you use the existing drawbar it doesn’t fit both.
ac160 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac160 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2022 at 6:53am
I think it should.  Have a similar one that was used once or twice on a wd45 w/o issues.  Probably wrong here, and don't have a book for one, but wouldn't you take the bail off to use it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote james6600 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2022 at 7:01am
Yea I can’t find any info on this model SS. There’s one for sale by me but I’m not sure it will fit. I haven’t been able to find the newer style with the straight shank and snap coupler.
Post Options Post Options   Thanks (0) Thanks(0)   Quote james6600 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2022 at 1:54pm
Anyone else have any experience with this SS on a snap coupler draw bar.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2022 at 1:59pm
On a non-snap coupler drawbar, the bail never falls off the tractor. You pull the two quick pins and it floats up and down. On the snap-coupler drawbar set-up, the bail has slots on the upper ends. So, when you pull the bail quick pins, it falls off the tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote james6600 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2022 at 2:25pm
Ok so I think what is called the bale is the U shaped piece that adjusts the draw bar up and down on a snap coupler tractor. So if I’m understanding this correctly on a pin hitch you pull the pins and the draw bar moves up and down with the SS which isn’t possible on the snap coupler tractor because of the slots. Am I understanding this right.
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2022 at 7:12pm
My wd disc plow hooks up this way too
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2022 at 7:13pm
And you got it right
Roger Mn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roger Mn Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2022 at 7:59pm
also remove your PTO shaft
Post Options Post Options   Thanks (0) Thanks(0)   Quote james6600 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2022 at 8:31pm
Thanks for the help everyone.
