I40
Glenblakeri40 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glenblakeri40 Quote  Post ReplyReply Direct Link To This Post Topic: I40
    Posted: 25 Sep 2022 at 5:45am
Hi all I'm new to this form I just inherited an I-40 from my grandpa hasn't been used for many many years needs a lot of TLC but been messing around with it using the backhoe and all of a sudden now it just stalls I reach over start it right back up use it for 20 seconds it stalls sometimes it'll sit on high idle install start it right back up any help would be awesome
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2022 at 6:27am
floating 'krap' in the gas tank !! unless you pulled tank and super cleaned it and all the lines/filters,etc.....
My D-14 'old reliable' stopped dead one day even WITH a full tank of gas..
...finally found a thin 'sliver' of yellow plastic IN the threaded input 'tube' section of the sediment bowl !!
The 'Light bulb' came on 2 hrs later....it's a piece of the yellow  plastic gas can nozzle.....
no idea how LONG it'd been in the tank....
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2022 at 7:23am
Should still have a sediment bowl at tank outlet, pull the bowl then the plastic screen above it (Press fit into housing), was where I had issues on my 180 and DocAllis led me to.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glenblakeri40 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2022 at 8:07am
Ok thanks all I'll try that today. I was thinking it had something to do with the hydraulic valves at the backend because sometimes if I more the lever back and forth it revs up again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2022 at 5:38pm
You might be shakin the tank...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glenblakeri40 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2022 at 6:04pm
It was crap in glass thing.all good now thanks everyone
