B rear splined axle
TMiller/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Topic: B rear splined axle
    Posted: 04 Oct 2010 at 4:47pm
Has anyone repaired the splines by building up with wire welder and turning back and re-cutting the splines in a milling mach?  Will the axle become to hard to work?  Will it become brittle or stress crack?    Thanks,  Tim
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2010 at 5:02pm
I just stuffed in some aluminum shims,  OK so far.  I have heard that it is usually the hub, not the shaft that gets beat up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2010 at 5:12pm
I patched one once by grinding off the back side of the hub ( with a hand held grinder) so it would go on farther and added a washer on the outside behind the nut. Just depends how worn things are and I agree, the cast hub is probably worn more than the shaft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2010 at 5:58pm
Dr Allis, is the hub cast iron or a weldable malleable ?  Thanks,  Tim
