AC 6080 Starting Issue
REM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote REM Quote  Post ReplyReply Direct Link To This Post Topic: AC 6080 Starting Issue
    Posted: 05 Sep 2022 at 5:17pm
I have a intermittent problem, when starting.  Sometimes I get click sound when turning the ignitions switch to start.  If I switch it off and try again it will usually engage the starter the second or third try. Sometimes it engages on the first try.   I checked the battery voltage and it is fine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2022 at 5:26pm
Kick down on the clutch pedal really hard. That safety switch is the usual suspect.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2022 at 5:35pm
PTO safety switches.  There are 2 of them.  They are the usual suspects.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2022 at 9:28pm
Install a relay between big white wire and starter if it don't already have one.                 MACK
This page was generated in 0.285 seconds.
