Gleaner L2 Header Wobble BOX
KY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KY Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner L2 Header Wobble BOX
    Posted: 03 Oct 2010 at 6:22pm
I have a Hart Carter wobble box bearing down on on my gleaner header. I can not get the drive pulley off of the wobble box to access the bearing. Does the pulley unscrew? It has a nut made on it and it also had a jam nut against it that i have already removed. I have used heat and a long bar.
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2010 at 7:30pm
Heat, penetrating oil, long bar, are the only way to go.  We couldnt break ours loose with our 1" impact wrench, so used 1" drive socket and handle, long cheater, and was able to get it that way.  If you break the pulley (I broke 1) be prepared for major $$  for that matter, depending on the bearing you are probably looking at close to $100 right off the bat.  I have several more to put together so we have a spare for fall harvest.  Good luck!
KY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KY Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2010 at 7:52am
It doesnt unscrew backwards does it? In other words its not backwards thread is it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2010 at 8:01am
Not to the best of my memory. Its been a while since I tore one apart last.
KY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KY Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2010 at 11:23am
Well We heat ,beat, cussed and used a 1" impact. The pulley busted off the nut but it still wont budge and its almost rounded off. Found another wobble box on a junk header to finish this year until I can fix that one. Pulley from AC is 460.00.
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2010 at 12:21pm
After breaking a few of the pulleys, I stopped useing alot of heat, seems it changes the metal and it will break.   A six point socket and a looong cheater bar, hitting the cheater with a sledge hammer helps-the guy holding the bar needs thick gloves.
KY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KY Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2010 at 2:12pm
Any of yall wouldnt happen to have an extra pulley laying around that you would sell do ya??? My extra wobble box turned out to be a bust and im not done with beans yet.
corlewfarms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corlewfarms Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2010 at 7:59pm
i think it screws off
Dave H (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2010 at 9:48pm
just cut the brg off with the torch, the pulley will come off easy and save you 460 bucks just did one today
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2010 at 9:52pm
Dave, try the plasma cutter instead of the torch.  Less heat and works faster.  For some reason the pulley comes right off then.  Doesn't ever seem to want to come off easy though, without the bearing off first.
