Porta-band bandsaw |
Thad in AR.
Joined: 12 Sep 2009 Location: Arkansas Points: 9733 |
Topic: Porta-band bandsawPosted: 21 Aug 2022 at 4:13pm |
My old portercable died. I tried to fix it but no such luck. It needs several parts and a couple are obsolete.
Been looking at the Bauer at HF. This isn’t a tool that will ride in my work truck or I’d buy a new Milwaukee. This is just for my projects in the shop. Anybody tried one? The reviews aren’t bad. Edited by Thad in AR. - 21 Aug 2022 at 5:51pm |
Codger
Posted: 21 Aug 2022 at 5:20pm |
Have seen several relatively new not make it through a job and thrown out. Most are either trigger, or brush/commutator related problems. Too cheap to put any time into for repair so replaced.
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90871 |
Posted: 21 Aug 2022 at 9:37pm |
I dont have one, but your right, the reviews are 98% positive... I would think for normal , around the house it should work out.... A lot of power tool life depends on how hard the tool is PUSHED.. Dont drag it down and pull the full 10 amps and i would think the life would be good.
Like Codger said, switchs seem to be a big problem, with ALL tools.. I have replaced several over the last 40 years.. They get cheaper and cheaper ( construction) as most are made in CHINA.
bobkyllo
Joined: 14 Sep 2009 Location: minnesota Points: 1569 |
Posted: 14 Sep 2022 at 9:11pm |
I've got two Milwaukee portable band saws. Worst thing I've ever used. They are more like portable scroll saws. I could never get a straight cut
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25272 |
Posted: 15 Sep 2022 at 6:05am |
re: I could never get a straight cut. Could be crummy blade and not setup right. I bought one of China's finest '4by6' bandsaws 30 years ago.Put an 'economy' blade in,BAD mistake, back to 'bimetal blades, since then, every cut dead true. I bought a spare machine for $100 at yardsale, just in case. Never had a need for a handheld unit,curious, what does someone use it for ? |
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12422 |
Posted: 15 Sep 2022 at 6:33am |
Thad, I bought one for a very specific job a couple years ago. It worked fine, but, literally have a bout an hour on the tool, so I'm not much help I guess. The job I had pinched and sprung the blade more than once, and I've never gotten around to replacing the blade, so there it sits.
dee_veloper
Posted: 15 Sep 2022 at 10:49am |
I have the HF saw and it works fine. I built a stand for it and use it a lot. |
Don't confuse my personality with my attitude.
My personality is who I am. My attitude depends on who you are. |
