ISO Power Steering Line for D17 series IV |
thester
Joined: 31 Jul 2022 Location: Marietta MS Points: 15 |
Topic: ISO Power Steering Line for D17 series IVPosted: 11 Aug 2022 at 7:32pm |
Looking for power steering line for D17 Series IV. If sitting on tractor it is the small line on the left side. Runs from pump to left side of reservoir on from of tractor.
DrAllis
Posted: 11 Aug 2022 at 9:28pm |
I'm going to assume a gas tractor ?? Diesel lines are all different. Lines from a series 3 are the same as a series 4.
thester
Posted: 12 Aug 2022 at 5:49am |
Yes Sir. You are correct and thank you for the response. If I were to try and build a line myself. Would you know the size of the line # 5 and fittings?
DrAllis
Posted: 12 Aug 2022 at 6:33am |
That's the pressure line, so it must be good enough for 1600 psi. If you don't have your old one for a pattern, that will be a challenge to make one identical. The pump hole is "inverted flare" which is kind of odd. The bottom is too, but you could make it into JIC connections.
thester
Posted: 12 Aug 2022 at 7:18am |
I have the old one for a pattern and I should be able to reuse the fittings. I’m just unsure the exact size of the steel line. Once I have formed the line I should be able to have a high pressure hose attached.
Albert
Posted: 13 Aug 2022 at 7:53pm |
I am sure it is a 5/8 line but you better measure it. A 5/8 open end quality wrench will tell you.
Albert
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5276 |
Posted: 14 Aug 2022 at 6:27am |
If you have the line; Send it to Inline Tube to have a replacement one copied from it.
VaAllis1990
Joined: 26 Jan 2022 Location: Champlain Va Points: 34 |
Posted: 14 Aug 2022 at 7:20pm |
Agco still sells it
Albert
Posted: 14 Aug 2022 at 7:35pm |
70237389 NLA from AGCO
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7639 |
Posted: 15 Aug 2022 at 5:12pm |
If you have the old one, a local hydraulic shop can make one to match it.
thester
Posted: 08 Sep 2022 at 6:51am |
Thanks for all the responses. Found the line from a gentlemen in PA via EBay.
