D14 block with d15 series 2 rebuild kit? |
BillM
Joined: 08 Aug 2022 Location: Pennsylvania Points: 6 |
Topic: D14 block with d15 series 2 rebuild kit?Posted: 08 Aug 2022 at 9:30pm |
Everything I have read so far says the only difference between a D14 and a D15 series 2 engine is the bore size. Am i correct in this? Wanting to use a D15 (160ci) rebuild kit in a D14 (149ci) block. Will this work or am i missing something?
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90561 |
Posted: 08 Aug 2022 at 9:52pm |
160 has a bigger carb, hi idle is 2000 rpm , i think different intake manifold...
the kits say ...." for SN 9000 and above"... Edited by steve(ill) - 08 Aug 2022 at 10:08pm |
DrAllis
Posted: 09 Aug 2022 at 7:34am |
Maybe could be done BUT, the sleeves won't fit in the block because they are larger O.D. So, you might be able to bore the block, but the cost might keep you from doing it.
Also, the connected rods are different as the piston pin diameters aren't the same.
Edited by DrAllis - 09 Aug 2022 at 7:37am |
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5271 |
Posted: 09 Aug 2022 at 7:35am |
WON'T WORK without a lot of costly machine work. The 160 sleeves have a larger OD than the 138/149 sleeves.
The only difference in the manifolds is the series II has a threaded exhaust port as apposed the the series I which is smooth. Send me a PM with your email if you want more help in BIG power from little engines. I have a NOS 160 block available.
Edited by PaulB - 18 Aug 2022 at 1:50pm |
BillM
Posted: 09 Aug 2022 at 8:06am |
Message sent
