Glass replacement
KRAKMT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRAKMT Quote  Post ReplyReply Direct Link To This Post Topic: Glass replacement
    Posted: 20 Jul 2022 at 5:48pm
I need to replace a couple windows in a piece of equipment. Anyone have a line on helpful tools and replacement rubber seal?
Current seal is pretty brutal, has shrunk and might be easier/better to replace?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2022 at 6:05am
There are various types of rubber gasketing, when you get that, remember the name of it, and search youtube, lots ov how to videos...
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2022 at 3:03pm
DIYDave:  Thanks for pointing out the excellent reference video.  Very Helpful ~ Orangeman
Wispitfiremike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wispitfiremike Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2022 at 9:12pm
I am a glass contractor, try CRLaurence.com for material and install tools.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRAKMT Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2022 at 11:47am
Thanks everybody.
I dropped it off with my brother who knows a glass guy.
Thanks also for tool/seal clue.
Rubber seal looks like trim-lok one piece but I will check out Lawrence
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2022 at 3:28pm
Well I replaced rear window on backhoe with Lexan sheet material and used broken window as a templet to cut material .
 On dump truck window I found a used glass but that gasket was worse than my original so I cut several sections and mounted windshield with those sections holding it in place , then used black silicone to fill in gaps and edges . Now it might sound like a hack job but on a 66 White 4264 windshield that when installing is from the inside install / not put in from outside, it was the easiest way of doing the job .
This page was generated in 0.087 seconds.
