WD Manifold Gaskets - question/opinion |
snowman(MI)
Joined: 12 Sep 2009 Location: Sand Lake, MI Points: 386 |
Topic: WD Manifold Gaskets - question/opinionPosted: 17 Jul 2022 at 7:25am |
I had recently purchased a set of manifold gaskets for my WD. Upon opening the package and spreading out all the pieces, there are two gaskets each for the exhaust and intake ports along with the thin metal retainer. In as much that these gaskets are thin, and the last set didn't last very long, what are people doing relative to installing two gaskets at each port or simply installing one gasket. Wish I could get a set of the old OEM gaskets that probably had thicker asbestos type of material. So one gasket or two per port? One other question would be, once installed do you ever retighten after a couple hours of running the engine? Thanks snowman(MI) |
1950 WD, 1966 D-10 III, 1961 D-10 II, 1966 D-15 II Gas, A-C Minibike, 917 Hydro Mower, 917 Hydro Blower w/cab, West Michigan "Allis Express"
DrAllis
Posted: 17 Jul 2022 at 7:29am |
If you don't re-tighten the nuts when the engine is COLD everyday for several days (this assumes you use it everyday) you will have early failure of gaskets. If your manifold isn't flat, that is bad. As far as the quality of your gaskets, I can't tell by looking.
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5282 |
Posted: 17 Jul 2022 at 7:31am |
There are 2 type due to being 2 types of manifold out there. You will not find asbestos in gasket anymore due to it being a cancer causing agent.
Use a fiber and steel set that matches your manifold and put RED Hi Temp RTV on all sides of the gaskets and it will still be holding when your grandkids take over ownership.
snowman(MI)
Dr. would you install the two or singles at each port?
DrAllis
Posted: 17 Jul 2022 at 7:55am |
I've never doubled things up. It's harder to crush two gaskets tight that it is one.
snowman(MI)
Posted: 17 Jul 2022 at 8:06am |
I would agree, just thought it was strange that there were 2 gaskets per port, or the folks sell these know that they don't last long. I will follow the advice of the tightening after some running of the engine. Always curious as to what others have done with these gasket sets.
DrAllis
Posted: 17 Jul 2022 at 8:13am |
RE-tighten when COLD after running it at operating temps.
snowman(MI)
Posted: 17 Jul 2022 at 8:14am |
Will do, thanks Dr.
Alex09(WI)
Joined: 15 Mar 2012 Location: CECIL WI Points: 1779 |
Posted: 18 Jul 2022 at 3:50pm |
As a business that sells both those aftermarket gaskets and the OEM ones, I believe they recently started including 2 gaskets for each port to match the thickness of the OEM ones when all assembled. If we use those in the service dept, we use both gaskets in each retainer. Also do like Paul says and put hi temp silicone between each layer like a sandwich!
www.awtractor.com
A&W TRACTOR 920-598-1287 KEEPING ALLIS-CHALMERS IN THE FIELDS THROUGH THE 21ST CENTURY |
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4079 |
Posted: 18 Jul 2022 at 11:28pm |
better take a straight edge to the manifold it has to be flat and a little meat around the ports it can not be eroaded to a point around the exhaust ports
