Starter for '50 B
Kayaker120 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kayaker120 Quote  Post ReplyReply Direct Link To This Post Topic: Starter for '50 B
    Posted: 01 Oct 2010 at 7:26am
My starter is warn down. The copper nub that sticks out from the starter has warn down so much that the switch (new) won't make contact. Any idea how to build up that nub?
Thanks,  Dan
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2010 at 8:56am
It can be replaced. You have to disassemble the starter and remove the stud. It should be soldered. I had a new one put in my G starter. I brought it in cleaned up and in a basket and the shop put in a new stud and replaced the brushes for $50.
 You might be able to solder some to build it up as long as it doesn't get  hot enough to break the connection to the wire inside.
Edited by CTuckerNWIL - 01 Oct 2010 at 9:00am
