How to Remove wd45 hand clutch shaft
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Topic: How to Remove wd45 hand clutch shaft
    Posted: 30 Jun 2022 at 8:20pm
I have a lot of slop in my hand clutch lever so I pulled the lever. It needs two new bushings but the shaft is badly worn as well and will need to be replaced. I know the shaft is frictional fit. I can get it to spin with a pipe wrench and a cheater bar but anyone got any ideas how to get it out?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2022 at 9:15pm
Pull right frame, weld nut the size of your slide hammer to end of shaft, and pull it out.                              MACK
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2022 at 7:27am
I take the shift tower off and pound it out from the inside.
http://lonsallischalmers.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2022 at 1:14pm
I had no luck driving out from inside.
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2022 at 7:11pm
Tried Mack's idea and snapped the shaft.
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2022 at 8:39pm
Ended up drilling a 7/16 hole though the shaft near the housing and VERY SLOWLY pulled it out. Took a ray Wylie Hubbard and a Tom h hall CD to get it out. Got advice on putting new one in. Think I will chill it in dry ice
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2022 at 11:22pm
have something between it and the hammer or you'll end up swelling the end
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2022 at 6:30am
Thanks everyone
