Where to find power jet for D15S2?
Dean (West MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean (West MI) Quote  Post ReplyReply Direct Link To This Post Topic: Where to find power jet for D15S2?
    Posted: 20 Jun 2022 at 4:43pm
I sent a carburetor off a D15S2, (MS TSX 869 type C) to a rebuild shop and it came back without a power jet. Does anyone know where I can find a power jet?
Part number 70240984?
This place list one, part number 49-159, but when you click on it, the description says it's for a TSX 899, Types A and B. I have a type C.
https://www.carburetion.com/CarbNumber.asp?Number=TSX-869%20(237860)
Also 70224061, according to the picture, it's a drain plug with a little valve on it to drain the float bowl.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2022 at 6:07pm
Did the carb shop lose it or you did not one to begin with?
Seems that shop ought to be able to help
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2022 at 9:36pm
Power jet from WD45 and D17 with Marvel Schebler carbs would work. I'm sure they are slightly larger hole size (drill #52 or .0625" ) but you should be able to lean it down with the adjustable main jet with the "L" handle.
Edited by DrAllis - 20 Jun 2022 at 9:37pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean (West MI) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2022 at 10:43pm
I purchased a rebuilt carburetor from All States Ag Parts 2-2016. Once I received the carburetor, I returned the old carburetor for a core charge. I installed the new carburetor, but had issues getting it to run properly. So, I parked it in the polebarn until I could look into it more.
Fast forward to 6-2022, the entire fuel system needed attention. I tore down the carburetor and discovered it was missing the power jet. I'm hoping the threads are still there, I'm worried they sent me a carburetor we with bad threads, and that's why they didn't screw in the jet.
I had to go through old emails to piece together what happened.
Edited by Dean (West MI) - 20 Jun 2022 at 10:45pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean (West MI) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2022 at 10:44pm
Thank you. If I can't find the correct jet, I will try your advice.
Model 70 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Model 70 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2022 at 9:07am
Check with carbs unlimited they have them, if you want new
