WD/WC Questions
jshoemaker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jshoemaker Quote  Post ReplyReply Direct Link To This Post Topic: WD/WC Questions
    Posted: 30 Sep 2010 at 9:35am
Will the WD wiring diagram work for the WC, are they similar enough?
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2010 at 9:49am
They are similar, difference being if you have magneto or distributor ignition. The WD usually has a key switch, the WC usually has a push/pull switch. Noticed I said usually. after 60 to 70 years anything is possible.
Goose View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Goose Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2010 at 9:56am
I may be wrong, but I don't think WDs had key switches. I have a 53 and it doesn't have one. It's just a push-pull switch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jshoemaker Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2010 at 10:09am
I am wanting to wire the two head lights, a bullet tail under the seat to the light switch, a push button floor starter switch and a push button kill switch together, and then just the normal... amp gauge, generator, starter, etc...  The WC I have has a distributor on it not a mag.  Any help?
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2010 at 10:23am
I have them both ways, although the ones with key switches are 1953 models with distributor ignitions. I need to get a new group picture, there are a few more now.
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2010 at 10:35am
We had a '53 WD, curved gearshift, and it had the key switch and distributor ignition.  I thought it was the most powerful thing around ( proud? who? me?) until the D17 showed up.  I had to start over.
Edited by JoeO(CMO) - 30 Sep 2010 at 10:36am
This page was generated in 0.060 seconds.
