Generator |
Neegan
Joined: 09 May 2022 Location: Moncks corner, Points: 29 |
Topic: GeneratorPosted: 17 Jun 2022 at 4:36pm |
Anyone have the part number for the generator that fits a 1968 HD16DP S# 8706? Don't have a parts manual but my service manual doesn't give me the number. Thanks
Ian Beale
Joined: 03 Oct 2011 Location: New South Wales Points: 1009 |
Posted: 17 Jun 2022 at 6:50pm |
Try the parts manual on line at MinnPar
Neegan
Posted: 17 Jun 2022 at 9:33pm |
Thanks, I found it right there.
Codger
Posted: 21 Jun 2022 at 7:02am |
If'n it were me I'd upgrade that charging system using either a 20SI, or 33SI series Delco alternator myself. The old generators were good no doubt, but brushless alternators have many less parts to wear and require no periodic maintenance.
Neegan
Posted: 21 Jun 2022 at 11:59am |
Well I found that the generator is working so I'm going to replace the regulator. I don't think the regulator should rattle if you shake it.
![]() I'll look into changing over to an alternator when this generator gives up. Thanks
Lee Bradley
Joined: 13 Oct 2009 Location: Kingston, WA Points: 120 |
Posted: 22 Jun 2022 at 11:39am |
If you want to keep the orginal look, you can go with one of these alternators.
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25219 |
Posted: 23 Jun 2022 at 6:30am |
FYI.. that unit needs an external regulator....
Neegan
Posted: 25 Jun 2022 at 9:07pm |
Thanks for the info gentlemen.
