Sourcing a H3 Drive Sprocket and Axle(?)
Twelve13 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Twelve13 Quote  Post ReplyReply Direct Link To This Post Topic: Sourcing a H3 Drive Sprocket and Axle(?)
    Posted: 05 Jun 2022 at 9:11am
Does anyone have a right side drive sprocket and axle (not really sure what to call it, but the part the sprocket bolts to) for a H3?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2022 at 9:27am
Eldon in Washington was selling parts. HTH Tracy
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2022 at 7:36pm
I check tomorrow if am still have a sproket shaft for H3
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2022 at 9:38am
I was up to an old Allis dealer last weekend that speciallized in the crawlers & dozers. He has lots of parts units and LOTS of NOS allis crawler parts left. He is in the U.P. of Michigan, call Mike @ 906-353-6119
www.awtractor.com
A&W TRACTOR 920-598-1287
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2022 at 12:16pm
I check this morning and have a sproket shaft for H3  ,he has 8 holes 5/8 inchs fine tread and found a parts number --43347--
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2022 at 11:45am
if there is wear at the seal area on axle shaft - a speedy sleeve and oversize seal can be obtained from a bearing supplier to solve that problem
Post Options Post Options   Thanks (0) Thanks(0)   Quote Twelve13 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2022 at 6:37pm
I appreciate all the replies! I am currently in contact with Eldon in WA about it. I will definitely keep that dealer in mind for anything else I might need! I would add a sleeve to the axle, but the axle and sprocket are missing entirely!
