D17 and 82S mower
Post Options Post Options   Thanks (1) Thanks(1)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Topic: D17 and 82S mower
    Posted: 03 Jun 2022 at 6:40pm
Finally got my 82S on my D17. Oh how nice it is to have power steering unlike my WD. Happy day for me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2022 at 6:40pm
Dang it, turned my darn pictures sideways and I can’t fire out why
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2022 at 7:13pm
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2022 at 7:51pm
see if this works
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2022 at 7:51pm
Thank you Steve. Please tell me how you did this so I can fix it in the future.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2022 at 7:31am
You're getting that 17 whipped right into shape!
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2022 at 8:38am
Thanks Mike, have a long ways to go but hopefully the end result will be nice. Need to get a good muffler for it. That shorty puts diesel smoke right in my face while driving lol. I have a sticker on my truck that says” I love the smell of diesel smoke first thing in the morning”. But I don’t like to choke on it.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2022 at 8:50am
I wouldn't mind having a set up like that.
Is that a seven, or nine foot bar?
Looks good 👍
Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2022 at 8:54am
Robbie, i dont know why, but sometimes the pictures seem to rotate 90 degrees when you install them... I keep the photos on my computer desk top... I just open them in PAINT and then ROTATE and SAVE as a different NAME... Then download again.. I have had that happen several times.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2022 at 11:47am
You are going to love your mower.
The Hi-Lo range and power steering on a D-17 makes it ideal for cutting square corners without stopping which most mid-mount mowers can't easily do.
Back in the early 70s my neighbor used to let me borrow his D-17 and 82S in the fall to "clean up" around my place.        It wasn't until many years later I was able to get myself an 82S but I had to mount it on a WD-45 as I hadn't yet gotten a D-17. I picked up a D-17 a few years ago still haven't transferred the mower over but it s on my "to do" list.
Since I use my mower mainly for 'trimming" and mow around alot of scrub apple trees and such, I cut the bar down to 5-1/2' and tweeked the linkage so the mower lifts to full upright position with the hydraulics.
Michael Crowe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2022 at 1:11pm
Here is mine on a WD45 with power steering.
The 15th Annual Exclusive AC Swap Meet will be held in Boonville, MO, March 6-7, 2026. See the club website for details: http://www.moacclub.com/
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2022 at 7:07pm
I'd like to find a 3point mower like that for occasionally use with my D-10 series III.
 Dusty
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2022 at 7:47pm
Fired up the D-14 with power steering and the 82S mower for two miles of rod ditch bank mowing. Great improvement over the WD-45 with the 80R mower. Added a second hydraulic cylinder to lift the cutter bar fully vertical
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2022 at 10:14pm
The side mount 82S saves my neck. I had neck surgery 6 years ago and I do not have full movement anymore. So seeing the mower with only a slight turn of my neck is the main reason I wanted it. After using it on my WD it surpassed my expectations. Just needed power steering with 650 lbs hanging off the side. Now I have PS and high and low which makes it a perfect combination.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2022 at 10:35pm
Dusty, that 82S will fit your D10.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2022 at 5:54am
Can't say for a fact, but I don't think so. And I would think that would be too much weight to add to middle of a D-10.
 I just want to trim around the edge of our pond a couple times a year. A 3 point would be easier to mount.
 Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2022 at 5:59am
 Dusty
I use a 80R on my D10/12
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2022 at 6:04am
My D-10 has a 3-point. It looks like the R-80 is for the Snap-Coupler.
 Thanks,
 Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2022 at 9:12am
80-R3 is the 3 point version
Charlie
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2022 at 6:07am
I would like to find an 82R with the tail wheel and mounts on the 3 point. Any out there for sale?
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2022 at 9:46am
 Thanks,
 Dusty
Here is what it looks like on my D10.
My dad purchased it new in 1968 along with a D15.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2022 at 9:52am
That's the one I'm looking for. But well worn, don't need to be in excellent shape, just want to do a little trimming around our pond.
 Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2022 at 11:43am
Ours has extra pads welded to the skid plate as it wore thru. I had to replace all the sickle hold downs and wear plate as well as the guards. $200+ just for that.
I need to replace the sickle drive hickey puck thing with the groves in it as it's worn also.
Be care of getting worn out stuff!
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2022 at 9:47pm
Spent part of the day spreading her legs....ya know losing the locks and spinning the wheels out to give her a better stance and stability. With 650 lbs hanging off the side, the wider the better. Also spent 4 hrs drilling and removing broken bolts holding the side panels on. Ahhhh, never a fun job.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2022 at 9:51pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2022 at 10:00pm
Darrell its a 9’ cut
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2022 at 6:04am
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2022 at 7:35pm
Mowed some more today. The diesel runs well with no leaks. Even the injection pump isn’t leaking at the banjos anymore. Previous owner only used it on his generator and would start it to keep the battery charged up. Since I’ve put a few hours on it even the power steering is working smoother. Someone put ATF in it instead of oil. Not sure if I should go back to oil or leave it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2022 at 7:34am
Pretty sure my D-17 had ATF in the power steering. I think that is the correct fluid for them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2022 at 7:56am
I really do like that mowing combination, looks awesome!
Darrel
This page was generated in 0.223 seconds.
