TSX 464 carburetor
Rod in MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod in MN Quote  Post ReplyReply Direct Link To This Post Topic: TSX 464 carburetor
    Posted: 28 Sep 2010 at 10:11pm
HI Guys it's been a some time That I was on here I have a WD 45 with TSX 464 carb was full of rust  cleaned the best i could with not able to get the nozzle out put it on the tractor but would not run smooth. Tighten up the High Adjusting needle The Threads pulled out. Drilled out the Nozzle out and the Thread are not good they look like 3/8 Fine .Need to know what size nozzle and adj needle are . Has any one ever drill out and Install  He-a-coil (not sure on spelling) in the carb to fix the Thraeds . Were can i find a Break down and part numbers
 Thank You Rod in MN
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2010 at 10:53pm
