D17 Duals
Travis2766 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis2766 Quote  Post ReplyReply Direct Link To This Post Topic: D17 Duals
    Posted: 16 May 2022 at 10:19pm
Picked up a set of duals for my D17 (cheap), looked online to try to find pictures and really couldn’t find many. Figured someone might want to see them, I don’t really need them but I think they look pretty bad azz!
Edited by Travis2766 - 16 May 2022 at 10:22pm
190XT Series III, D17 Series IV, D15 Series II, All Crop 66 and a whole mess of equipment.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2022 at 10:24pm
You won't believe what a difference it makes in plowed ground discing.  The disc even works better !!!
Edited by DrAllis - 16 May 2022 at 10:25pm
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2022 at 1:33am
In plowed ground your tractor won't leave nearly so deep tire tracks. You'll see a big improvement in how the disced ground looks. They will cause wear on brakes unless you make a wider turn,
 We had duals for our 180, silly me got rid of them when I quit using it on a disc. Now wish had them back. They were 18.4x28".
Play Farmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Play Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2022 at 6:08am
That looks pretty sweet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2022 at 7:29am
That not only looks awesome no doubt your traction really improved.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2022 at 8:52am
I've got a pair of 16.9x28 clamp-ons that would fit most 17's that I would sell..... Rims have nice fresh silver paint on them....
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2022 at 1:12pm
They do look pretty cool. That's a nice looking D17.
He's the duals on my WD45. I just wish I had 8" spacers instead of 10"
My Great uncle had different duals on this WD45 years ago. He put wide tires on it and used to to break open wet muck ground to let it to dry.
I have a set for my 185 too but I never tried to mount them.
Edited by Allis dave - 17 May 2022 at 1:14pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2022 at 1:21pm
Has anyone had final drive issues after running duals on these? It would put more stress on the finals that they weren't designed for. I always figured though if you were careful that you'd be ok. You should be running a few less PSI in the duals than in the mains. l've heard of several people running them without trouble.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2022 at 2:43pm
That's a great looking 45 Dave!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2022 at 4:06pm
Thanks Mike, Like Travis I thought they'd be cool.
When I was restoring this tractor, it was a goal of mine to get duals setup on it like my Great uncle did on this tractor.
I like plowing with the left dual on too. I have 3 weights on each side instead of fluid, and the dual really helps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis2766 Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2022 at 6:04pm
I like the 10” spacers on the wd-45, I like the look of an open platform tractor with duals. I have 300lbs of wheel weights on each side rear plus fluid. The duals do make a big difference in ride and as far as “lugging” power.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2022 at 6:23pm
Oh yeah , duals help a bunch and look so bad a$$$$
200Tom1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200Tom1 Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2022 at 11:15pm
I only used mine to plant corn. Made a big difference in soil packing.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2022 at 12:57pm
Originally posted by 200Tom1 200Tom1 wrote:
soil packing.
This is where duals REALLY make a difference.  By spreading the tractive effort over larger surface area, the path of travel is compacted substantially less.  Soil distributes load based on surface pressure and the 'cone of compaction'... meaning, if you put 100lbs on a round spot of soil, then measure the compaction underneath, you'll find that the compaction force on the soil below is spread out in a cone with basically 45 degree angles... and as you travel down that cone, the compaction result drops considerable (based on the increasing diameter of the cone).
Rolling a tire along a path, creates what is essentially a 'curb' of compacted soil, where the higher the pressure, the deeper the cone reaches, and the tighter the compaction occurs.
By increasing surface area, running duals doesn't cut that compaction by half... it cuts it into quarters.
As noted, having a dual on ONE side when plowing, helps balance draft.
Running duals on both sides also effectively lowers the roll-center of a tractor, by moving mass AND by moving support farther away from it's center axis,   If you're working across a grade with a narrow-front, running duals will have a significant effect on lateral stability.
re 'hard on driveline'... is a relative thing.  'what it's designed for' is not a particularly well-defined thing.  While having duals mounted increases likelyhood of stresses in some aspects, the design criteria for 'real' tractors takes into account much greater tolerances for overload than say, a Toyota Prius.  A tractor that's plowing through a field, regardless of wheels, etc, that hooks onto an imoovable rock or stump, will stop with an astounding yank... and the shock forces are really high.  Frankly, the loading which occurs from pulling an ordinary plow through ordinary soil isn't easily 'calculable', because there's so much variablility across the agricultural landscape, that one can't just assume a particular value and 'build to it'.  The only way to survive that, and all the other crazy things that occur in the realm of agricultural work, is to have plenty-more-beef there than MOST of the time.  Anything less, and you wind up with a Ford N or a Kubota. LOL
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2022 at 5:04pm
Wow Dave well said as usual! Thanks! Dana
Blue Skies and Tail Winds
                          Dana
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2022 at 6:39pm
To Travis , your D17 with duals is EXACTLY what we ran in the early '70's minus the loader arms (they were on the WD), brings back GREAT memories from my childhood Big smile !!
There was a local guy that ran duals on a WD45 but no spacer , that was a "BAD ASS" looking machine also Clap
MadCow View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MadCow Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2023 at 6:06pm
Found these pictures through Google and never realized I wanted something so bad.
That WD45 looks super slick!
I think a D17 is my next to add to my collection.
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2023 at 11:15pm
I have a set of rail mount loops for clamp on duals. Some day I hope to have a use for them.
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis2766 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2023 at 2:28pm
Once you find a D17 it shouldn’t be too hard to find a set of duals for it. I paid $100 for the the ones on mine, they’re not great and look better in the pictures but hey they’re duals and don’t need to be in pristine condition for the little work I use them for.
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2024 at 1:20am
Here’s my 45 Diesel with duels…
1955 AC WD45 diesel with D262 repower, 1949 AC WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2024 at 12:14pm
I have a pair of 16.9x28 band type duals I'm not using....
