RC V-belt |
Wot
Topic: RC V-beltPosted: 11 May 2022 at 12:57am |
Hello,
What would be the correct Gates number tot replace my V-belt (without generator) Guess it will be the same as a B without generator? I found number 22320, but don't know if that is correct. Thanks!
Edited by Wot - 11 May 2022 at 6:28am |
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5276 |
Posted: 11 May 2022 at 6:32am |
Yes: That is the correct belt for RC, B, C tractors & 125 Power units without a generator.
Wot
Posted: 13 May 2022 at 12:33am |
Thanks! Another question, my throttle works not the same as my B, towards engine is idle. Is that normal on the RC?
AaronSEIA
Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2584 |
Posted: 13 May 2022 at 5:45am |
I'd assume so. Thats how a WC is set up. AaronSEIA
WD45Diesel57
Joined: 20 Jul 2010 Location: Varna, Ont. Can Points: 646 |
Posted: 27 May 2022 at 7:40am |
thats the way my RC works as well, it think it has to do with the location of the throttle rod in relation to the lever! i think the RC is mounted above the pivot point and the B and C are located below the pivot point of the lever! In which will change the action of the lever! I could be wrong id have to double check my RC with the B
1-B's, 2-C, 2-CA's,2-WF, 1-WC,1-G, 3-WD's, 2-WD45, 1-RC, 1-D17 Diesel, 1-D14, 2-D15,1-D17 row crop,1-D19 gas and All Crop 40,60,66,72,90 and 100
