tractor pulling acident
smuggler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smuggler Quote  Post ReplyReply Direct Link To This Post Topic: tractor pulling acident
    Posted: 27 Sep 2010 at 7:21pm
Al Koch and John Lancasters'  Entertainer 2 breaks away from the sled.  I dont know how to put a link up.  There is a link on pulloff.com under feed back.    Or try you tube   entertainer 2 crash at earl park.  Very scary ride I beleve Norm greens son was driveing.  Totaly  the sleds fault in my opinion.
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2010 at 7:51pm
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote smuggler Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2010 at 7:58pm
thanks you JoeM
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2010 at 8:52pm
I have to ask why it was the sleds fault.  Looks as if it took a hard bounce and unhooked.  Did the chain break, hook break, does the hook have the extra piece welded on to help prevent this, hitch break.  I have seen this before, although usually with the mini's  Just a couple quesitons going thru my pea brain
'40 WC puller,'50 WD puller,'50 M puller '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote smuggler Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2010 at 8:59pm
I beleve the hitch broke. Im sure the sled had had the piece welded on the hook it looks like a lowry sled .  It is hard to tell in this video but the weight box on the sled is moving up the rails very fast and when it hits the end of the rails and box stop. It actualy drives the sled forward puting slack in the chain causeing the tractor to loose traction for a split second. Thats why the tractor went outa control on 1 wheel causeing the hitch to fail.
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2010 at 9:02pm
bet his butt snapped shut like a snare drum hahaha
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2010 at 9:04pm
Man, that looked scary.
Andrew(southernIL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew(southernIL) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2010 at 9:32pm
I seen a similar crash with a New Holland only he didn't break away; when the tractor bounced the sled actually ended up under the one rear tire that come off the ground and the nose dug into the ground.
If fishing is a sport your looking at an athlete
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2010 at 9:34pm
Yep, i'd have needed replacement shorts after that.LOL!
Jim Lindemood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2010 at 7:20am
Pretty tense moment for the driver and spectators. Driver did a good job and nobody got hurt -- easily could have been a sad story.
thumb farmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thumb farmer Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2010 at 7:41am
it's close but the box was still moving. front wen't high enough to lose drabar pulldown,  front cam down and tractor hooked back up.  At that speed everything happens so fast there is't much a driver can do just keep it straight and don't hit the brakes the kill switch shut the engine down.With helmet & fire mask,+cage you just are not aware of what goes on. I often tell friends, you'll know something wen't wrong before I do.
Post Options Post Options   Thanks (0) Thanks(0)   Quote smuggler Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2010 at 7:41am
Its hard to tell from the seat how bad it is happens very fast and since your sitting in the middle of the back wheels its kinda like sitting in the middle of a see saw. if that makes any since? lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote smuggler Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2010 at 7:46am
thumb farmer . I think the box triped out  thats why the tractor unloaded then reloaded. had it happen to me a few years ago at the fort.   The sled operators in my case were iron man sleds and they slam that box so hard against the box stops it unloads the tractor.  When singer has the exact same sled and puts more weight in the box and moves it ahead slower and it is as smothe as glass.
Allis Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Fields Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2010 at 9:21am
I saw the post on pulloff but didn't see the video. Very lucky driver.
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2010 at 5:01pm
watched it several times looks to me like the chain broke you can see it swinging under the tractor as he stops still very nice job on his part hold on and best of all nobody got hurt
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2010 at 6:04pm
woops my bad went to the other site the feed back is the hitch broke metal fatigue
