M100 grader
jhedmonton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jhedmonton Quote  Post ReplyReply Direct Link To This Post Topic: M100 grader
    Posted: 09 May 2022 at 12:09am
Just bought a M100 grader! Works well but after a coupleuploads/23019/20220507_190415sm.jpg hours of work the front steering hydraulic leaks badly. Are the seals/gaskets still available, if so where?
THANKS
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2022 at 9:03am
Is the hose tight? Can't tell from picture where it's leaking.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jhedmonton Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2022 at 11:50am
Hose is tight, leaking right behind that bolted front plate. Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2022 at 2:52pm
Looks like a Shepard gear. I think there is an oring on the cap. You could match it up at a hyd shop. I don't think you can screw up anything just pulling cap. Been a long time since I had one apart.
Codger View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2022 at 3:05pm
Start here: https://www.rhsheppard.com/
They used to have a very good technical support staff willing to help with older steering gear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jhedmonton Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2022 at 3:10pm
THANKS!!
