D21 clutch replacement |
Post Reply ![]() |
WLHD21 ![]() Bronze Level ![]() Joined: 06 Feb 2019 Location: Iowa Points: 155 |
![]() ![]() ![]() ![]() ![]() Posted: 03 May 2022 at 9:33pm |
Has anyone had luck rolling the back half of the D21 away from a blocked and supported front half?
Or is it best to remove radiator, front end casting and frame rails as called out in IT manual? |
MACK ![]() Orange Level ![]() Joined: 17 Nov 2009 Points: 7664 |
Best to role engine and front end forward. MACK
The concert that I see is that the frame rails do not connect to engine plate and the splitting stands I have will not support the engine, I will use an overhead hoist Connected to engine to move the front half forward.
Thanks |
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8664 |
Splitting stand I used on 8070,I blocked across stand rails and put jack under oil pan to support engine with frame rails.
A wood block under oil will easily support the weight of motor. MACK
Fred in Pa ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9210 |
This is what I use alot .On 190 200 180 etc . I got bolts with heads cut off run them bach throught engine plate n side rail and use overhaed gantry
Post Reply ![]() |
