6080 water pump
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Topic: 6080 water pump
    Posted: 30 Mar 2022 at 5:21pm
Hi all.
This might be a silly question.
We put new water pump on which I think was a hi-capacity  I believe the one that came off was also hi-capacity. So I came across agco rebuild kits. The question is can you rebuild the hi capacity housing with original agco rebuild kits.
Thanks
Edited by Mikez - 30 Mar 2022 at 5:24pm
Albert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albert Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2022 at 6:58pm
It looks like the kits are no longer serviced by AGCO but there may be some around
To answer your question yes the kit will be fine.
Albert
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2022 at 7:15pm
I have two kits on the shelf. Thanks Albert
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2022 at 8:43pm
If you never rebuilt one,  better have some help from some one that has. One mistake and you don't  even have a core.                       MACK
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2022 at 2:11pm
one has to cut the brg shaft and PRESS everything out , usually w/heat.  Pulling the hub and pressing out the brg 90% results in broken cast housing and warped hub. Failure to press on the hug and impeller to the exact dimension = failure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2022 at 6:57pm
Thanks guys. The guy doing it has done other water pumps. Not 6080 though
