Equipment failures and lack of parts
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Topic: Equipment failures and lack of parts
    Posted: 26 Mar 2022 at 7:04am
Seems ALL machine lines are ending up junk, HD Trucks, Tractors, Cars and Pickups, Motorcycles.
All the electronics that drive all those special added for comfort toys in the options packages are failing AT HIGH RATES, the dealers cannot access the parts as the new machines use the same parts and the manufacturers cannot get enough to finish the new lines.
WHY?  Why did the consumer NEED this added trash?  Why does a Dump Truck need a Climate Control or Suspension computer control system?  Why did CAN-BUS become the go to for everything including tail lights and turn signals when a Fuse on a wire or a simple flasher worked FINE?  Farm tractors that sit on dealer yards, bought but unusable as will not shift or engine will only idle or the pto will not electronically engage, all due to electronics wizardry to take the place of a linkage rod or cable or just simple systems.
Did the Consumer Require or did the Manufacturer decide for us?
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2022 at 8:20am
Manufactor greed, it makes them more money and they can say it's safer for you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2022 at 9:14am
I'm with you 100% - don't need all this electronic B's on these machines- can't get parts or a - qualified tech to fix them , complete failure
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2022 at 10:12am
While I didn't need the features the Buick Enclave has, I sure like them. Some features are consumer demand. Right or wrong, the CAN-BUS system was designed to reduce amount of wiring in a harness. More functions on fewer wires. Save weight and material. Don't believe the end user benefits from that. Cousin owns a fleet of trucks. New orders are out two years
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2022 at 11:47am
As a rule, if a company makes a habit of building what people don’t want, they won’t be in business too long.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2022 at 12:56pm
YEP... the build cheaper base line models, and fully loaded expensive ones.... FLEET might buy a few base line, but POPULATION wants fully loaded... They only build what people WANT.
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2022 at 1:03pm
Wink I think I agree with DMiller in we have way more electronic stuff on all mobile equipment than we need. Embarrassed  But for farm equipment AC was one of the leaders. In 73, or ? when the Gleaner L and M combines came out they had no mechanical linkages for the hydraulics, all by rocker switches and electric solenoids. LOL
Big smile But after you drove one with the header lift switch in the hydro handle.Big smile It was a real let down to run something less.Cry But then I sat a day waiting for a tech to come fix it so header would go down again. I believe it was a spring gone bad on a bee size check ball in the hydraulic valve. The tech knew what he was looking for, and 5 minutes and a magnet and away the MH went again. But he had done a week or what ever at AC combine school.
The beginning of common sense farmer mechanic may not be enough to keep the machine running.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2022 at 2:10pm
Most people generally buy what they're TOLD to buy.. 'keeping up with the Joneses', TV commercials, peer pressure, media hype. Very few just buy what they NEED.
Manufactures want to please shareholders, more money for them selling 100K cars then 24K cars...
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2022 at 2:15pm
Right... its what they WANT... not a NEED... They WANT all the bells and whistles.. You dont have to TALK THEM INTO IT... They know what they WANT..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2022 at 4:04pm
Cry that same tune over and over. Yes, it is a want. Yes there is marketing. Yes companies need to please their shareholders. And YES they do all of these things to make money AND they try to make more than they did last year. It’s called business. It’s the same for every company I’ve worked for and the same for my farm.
If what you said was so true, a company would come along, build simple inexpensive stuff, and sell it like hotcakes. Guess what, it’s been tried and doesn’t work so great. NOT ENOUGH MONEY IN IT.   Somebody gets one of those cheap ones, then they get in one that’s quieter, rides better, stereo sounds better, and yep I like it and buy a nicer one next time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2022 at 5:30pm
Evidently not seen the inside of a 2015 Western Star CAN BUS Dash.  It is a SNARL of EXCESSIVE amounts of wiring, are three looms feed to or from or in that cab, each is 2" in diameter and all 16 or 18ga wire on a High Vibration Severe Duty chassis.  Brainless is what it is.  Replaced less than a Dozen Air and Liquid Lines with MILES of Delicate wire and seven Control Modules, again BRAINLESS.  Has been stated by a Concrete Yard mechanic, all these machines need to start bursting into flame, claim Warranty.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2022 at 5:44pm
It's definately safer, no one dies in an idle machine!Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2022 at 6:07pm
Drive past a Dealer lot for equipment and do it again a week later, the Warranty repairs are paid for thru a ever increasing price tag for the machines, is paid for as you buy that machine except when repeat occurrences eat up all those moneys in a few years then that machine gets traded in and the Dealer has to support it, most dealers do not achieve said profit margin to do that.
Vocational Equipment, that which may not run loaded more than 50% of the time are the death of warranty expenses.  They generate repeat occurrences where to gain coverage enough to pay those warranties the machine prices go up drastically.  Machines sitting awaiting parts do not cost a dealership or manufacturer, non productive time becomes a pestilence expense most farms and trucking companies cannot afford.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2022 at 7:13pm
that's why the prices of older used machines have gone thru the roof! same with used vehicles/farm equipment/industrial equipment/anything that is motorized! a large trucking company has 2 people that travel the country and buy older tractors that don't have all the electronics in them, they get shipped back to the terminal, rebuilt and put back on the road. a friend bought a new green tractor last year, but had to wait to use it because of puter problems in it...after several months wait he went and got his money back and bought a different brand. another thought...would you want to put a new hired hand in a new computerized tractor right away? it won't look/run new very long! pretty soon we'll prolly see a spark plug on a hand shovel, wires going no where cept to a special box that sends a shock to your hands if you try to by-pass something on it! it's another reason scrap iron is high right now too...the big companies want to old perfectly good things to disapear so you have to buy their chit. i say keep the old few a few more years, let the manuf. sit in their junk. course you'd never get everyone to do this, but there would still be a hurt inflicted from it. this story could go on and on...but i'm sure ya'll get the picture! i'll keep my old Allis's and buy some that are headed to the scrap yard, just so the parts from them will allow others to live longer.
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2022 at 9:46pm
If everybody wants this new crap so bad then why is it that old 80's tractors, especially Deere's, have doubled in price? because many farmers want to get away from this computerized garbage.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2022 at 6:56am
re: a company would come along, build simple inexpensive stuff, and sell it like hotcakes.
Apple Iphones. Less than $50 in real cost to make, Could sell for $100, make  $50, sell for $1000, make $950 ! It's all about the bottom line
Lotteries, what sells more tickets, 50 , 1 million prizes or ONE $50 million winner. All about profit and greed
Energy control. 3 decades ago my energy control system was saving clients 30+% of their true energy costs for 5% of the savings. Feds  shut us down,costing them too much lost money.
CANBUS is a horrible 'can of worms' layered in doodoo with zero REAL need for how it's done.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2022 at 7:06am
I wonder if the cyber hackers can hack into all these computerized machines from afar and stop them dead in their tracks?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2022 at 7:30am
They DID do that with some Chrysler machines several years ago, supposedly can do with any of those as GMs system OnStar, Ford and Chrysler as well all the Foreign models can defeat or enable features without entering your car, KIA is noted in the news now doing so making certain features a Subscription and added fees for those.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2022 at 7:50am
All about the bottom line…Yes, I believe we’ve covered that. At work we manage to the bottom line every day. At my farm, not quite so frequently, but with dedication. $50 to make an iPhone, good for Apple. The price of anything is what the market will bear. If they can sell them for $1000 plus, good for them. You should have bought stock in Apple 20 years ago.
You made something that worked good 30 years ago, so did I. Then I had to make many more things since then.
If this way of things is all wrong, in time it will change, swing back the other way, or some other way. Things change.
Today a laptop is just as common in a toolbox as an adjustable wrench was 50 years ago. It’s the way it is. 20 years from now, today’s technicians will be whining about the good old days.
Kansas99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kansas99 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2022 at 8:37am
Yes some people don't want or need that crap, but I think one of the biggest drivers of used value is new value.  Say you need a 140 hp 2wd tractor, a low hour used or new one is say 200K but you only can afford 80K, well if you don't need the bells and whistles you can pay say 60K on a older one have 20K for repairs or to put in your pocket and a few years back that new one was 100K so you couldn't justify 60K for a old used one but today you can and thus the price of used is pushed up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2022 at 11:38pm
Son just got rid of his 2019 Quint Dump Truck , Western Star with big Detroit engine and Automatic - Spent more time in limp mode than hauling . Would run for a month and then  in shop for 4 days .
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2022 at 5:26am
And that Coke is the basis I wrote this for.  out of four weeks one week is lost to transit time losses and time in a facility most often getting a multiple regens until the damn DPF cleans up(EATING Fuel and DEF) and/or then a swap to a cleaned DPF while sensors got replaced as they too had failed during the events.
Major expenses eating at Consumer cost, eating at Contractor costs raising charges, leading to Dealers having to supply warranty repairs and NO they do not pay as well as Consumer Paid Repairs as Manufacturers tighten that knot pretty hard and finally Manufacturing where this all transpired as to adding those 'Expected' warranty repairs into the machine cost the Contractor pays and the Consumer responds in kind in adjusted UP expense fees.
At some point this self Eating/Feeding Watermelon collapses in upon itself and dies.  Growing to feed, feeding to grow but never outside its own skin, never really gets bigger or stronger just feeds.
modirt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote modirt Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2022 at 6:19am
Was at the farm past weekend. Drove two tractors I grew up on. One 1964.......one 1973. Neither has a computer chip. Simple mechanical systems that still work just fine.
I remember running a Gleaner L in 1978.....and those rocker switches. That was how I disabled the combine so owner couldn't run it. If he did......he would leave it broke down after he either slugged it down or hit something with it running after dark. But those rocker switches didn't do anything more than the two way hydraulic valves used on the other machines I ran before that.
There is a lot to be said for simple, reliable, rock solid mechanical equipment.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2022 at 7:21am
There is a basic truth about the concept of people buying what they want, or need...  and one can argue that completely, however, there is one fact that fails it:
One cannot buy that which is not offered.
I challenge anyone to go out and buy a 'simple' piece of machinery now.
You're not going to find one 'new'...  as some have already noted, you'll only find 'used.
There are many things that networked processors, sensors, and motion-control automation can do, that make operation of all sorts of things more capable, and this falls into one of three categories-  first is 'productivity', the next is 'safety', and the third is 'convenience'.  Fancy controls that enhance productivity, are like header height control, terrain mapping, soil monitoring, etc., and they do help in producing more in a broad sense.  Enhancement of 'safety' can be anything from fire detection to overheat, overload, lubricant temperature or loss.  "Convenience" is stuff like constant reminder that your windshield washer fluid is low, or the ability to randomly screw up your electrically-adjustable seat anytime your wife calls you on the hands-free phone feature.
'Feature Bloat' is when something gets loaded with all sorts of solutions to problems that don't really exist.  It is, for lack of a better description, just like government...
Manufacturers wouldn't have done this kind of problem, if the cost of all sorts of cameras, microphones, thermal imaging gyroscopic hygrometers, and tiny single-use telemetry devices with irreplaceable batteries, if all those components weren't dirt-cheap.
They also wouldn't do it, if people refused to buy boated-out 'expected-life' crap.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2022 at 12:01pm
Point in fact Dave, and Simple taken for granted garbage 'To Increase Safe Operation' as the little sensors in the Valve Stems of newer cars even to HD Trucks, the batteries are NON-Replaceable, Epoxied in place as are the tiny transmitter circuit boards.  NON-Repairable just throw them away for some $26 EACH TIRE including the spare that have to be changed to keep the alarm bell from dinging as the tires cannot be read for pressure.  Batteries go from between 5 and 8 years where they just quietly die.
Used to be a person Checked their tires during a Service, or asked when had a service performed, now its throw oil and a filter at the cars and Back to the Foray!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2022 at 4:00am
It's not what we want or anything else...it's all that is offered.
Also, I believe it's SOOoooo easy to put something in a CHIP that will make this piece of equipment fail at such and such a date/time.  Then the bill to LOOK at it is more than buying a NEW one.....
NOTHING is built to last anymore.  It can't be,,,,,,,,if they did that, they'd be out of business soon enough.  It's all about REPLACING rather than fixing...
It's all about the $$$$$
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2022 at 4:09am
Oh Yeah,,,,,,when was the last time someone from ANY company came out and asked YOU what you wanted??  I have yet to see anyone breaking down my door.
Let's make it better than the old so they'll buy it...... kind of like how they decided that the color of a car was pointed toward women.  They don't see a manufacturer......they see how pretty it is.
We don't get any input,,,, only a choice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2022 at 9:30am
As for what we want, what we're offered,  etc.  I get it.  Most of us here are plain country type folks who grew up wrenching on stuff.  So when it comes to "customer input", we are a minority type of customer.  But the reality is, customer input versus offerings ARE a real thing and it goes in cycles one feeding off the other.  A company offers a feature, charges more for it.  Turns out MAJORITY of people (present company excluded) like that feature.  Not only does the company make a little more money on the sale (WHAT THEY ARE IN BUSINESS TO DO), they then offer more features and by golly those are liked and bought by the majority as well, which makes the company more money, which they are in business to do.  If they don't they won't be in business for long.  It may not be a perfect system, but it is what we have and is better than others I've seen.
Wispitfiremike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wispitfiremike Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2022 at 11:40pm
Many of the features of new are driven by past insurance claims paid out from accidents. After a company loses a lawsuit they find a way to idiot proof it until the next time somebody wrecks something. Some are pretty easy to get used to but others like the new gas cans are a serious pain in the keister.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2022 at 6:50am
for the last week was considering saving my old F250.  Bought new 1999, Super Duty body line Super Cab and has been a dependable old beast.  So after a few days of looking thru availabilities have come to the conclusion NOT worth saving.
Can buy Patch panels for front doors, rear half doors are NLA so would have to opt into Scrapper Doors from??TX, CA, AZ  and then ship them in For ?$$$$$?  Looked to a Whole Cab, nothing older than 08 which does NOT interchange for Dash, HVAC and internals or harness bulkhead connection holes, interior parts would not swap adding MORE expense.
So can still get cab corner and inner rocker patch panels does no good without the rear doors..  Put in call to body shop owner here that we are friends with, he had same dilemma as to even foreign made replacements.  So tired and old will have to be disposed of as a Parts Truck, bud of mine in OK was wanting it for his Nephew but that may be out as that boy has gotten seriously stupid AGAIN on drugs.  Thinking may end up being driven into Salvage lot for what can give me for it when time comes.
