D grader starter
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Topic: D grader starter
    Posted: 24 Mar 2022 at 1:38pm
Will a starter from a WD tractor fit the grader motor? Trying to get mine to work and starter is history inside,--burned up bad.
My D is still on 6-volt system and is a 1950.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2022 at 6:09pm
Yes a WC, WD & WD45 starter will fit and work, however those starters will have a Lever type switch instead of a post to use the solenoid. You'll just have to lift up the seat to use the lever unless you Grader already has linkage for the lever type switch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2022 at 12:29pm
Thanks Paul! I think I have 1 starter that does have just the post. will check that and if needed I can lift seat to use the starter,--- no problem for me! lol!
Joe(TX) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2022 at 7:48pm
The WD starter can be converted to a solenoid operation. My WD has been.
This page was generated in 0.097 seconds.
