190 transmission rear end oil level |
brad7066
Topic: 190 transmission rear end oil levelPosted: 13 Mar 2022 at 7:42pm |
how much over the full line should i be running my 190. it has a coupler in it with no hydraulics
DrAllis
Posted: 14 Mar 2022 at 9:17am |
For pulling?? the higher the better, to flood the differential gears. Use light weight (HyGuard/HyTran/821XL/Permatran) oil, not 80/90 wt. Oil level can be as high as half-way submerging the top shaft in the transmission and then that will have the differential half submerged too. Needling the differential is a good thing.
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3630 |
Posted: 14 Mar 2022 at 1:41pm |
as to the front end - if you have no PD clutch - many take out the torque housing gears and put in sealed bearings so one needs no oil - IF you still have the torque housing gears we put oil jugs in bottom of center housing and foam to cut down on amount of oil needed -but you have to keep those cone/cup needle brgs in the front housing wet... about normal on RH dipstick...
brad7066
Posted: 14 Mar 2022 at 2:09pm |
differential gears have been needled was told by them to run mystik synthetic.
goomer
Posted: 14 Mar 2022 at 10:16pm |
I drilled and taped a drain plug on the circle plate on side of torque housing just about even with clutch main shaft. I keep filling until oil comes out. Takes a bit of time to get oil there.
