Which seals should I replace
John m View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John m Quote  Post ReplyReply Direct Link To This Post Topic: Which seals should I replace
    Posted: 27 Feb 2022 at 8:03am
I have my 190 split for intermediate gear work. While split I have pulled the power director, replaced the three sealing rings and the hub because of groves wore in hub. Should I replace seals on lower pto shaft while split? I have had no indication of oil leaking or being transferred from torque housing into trans. Any opinions are appreciated, John
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2022 at 8:12am
Yes, I would replace the PTO seals while it is split.                  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote John m Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2022 at 8:41am
Thanks, guess I better order a couple more seals. Looks like that will make them all done and better off safe than sorry. Doesn't look to be to hard company to the rest of the work I've done on it. Thanks again, John
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2022 at 9:00am
Pack those PTO seals in grease so the spring cannot fall out of place when you drive them in their bore.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2022 at 9:13am
look at it this way...
..whichever seal you do NOT replace WILL be the one that'll leaks a couple dayze from when it's 'up and running'.....Cry
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2022 at 9:26am
Also, be sure the upper seal on the transmission input shaft is only pressed in FLUSH with the O.D.   If you press it clear into the bottom of the bore, it will block off the drain hole on the bottom and you will be splitting the tractor again for oil transfer problems.
Post Options Post Options   Thanks (0) Thanks(0)   Quote John m Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2022 at 9:46am
Will do, I'll pack them with grease. I was real careful with the top seal and made sure to not block that lower oil passage like you said on one of your other posts. That hub had grooves wore in it so I replaced it and the steel rings in power director while I was in there. Thanks, John
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2022 at 8:39pm
I have a driver I made that keeps springs from jumping out . If you don't do something, they will jump out.                       MACK
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2022 at 8:47pm
Replace every seal in that general area.  Murphy's law that one you didn't replace will start leaking 6 months later.  Definitely do the PTO lever shaft O ring!
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2022 at 11:25pm
John while you have the PTO shaft out the rear of housing I'd suggest you replace PTO output seal and sealing Oring. You're already there and it's another $15.
Post Options Post Options   Thanks (0) Thanks(0)   Quote John m Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2022 at 8:22am
I have ordered all seals and o-ring so they will all be new. I definitely don't feel like splitting this again for a couple dollars worth of parts. As DrAllis told me before I started this it's a pretty big job. But, I'm enjoying it. John
