Any Yanmar experts?
Greg(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Greg(WI) Quote  Post ReplyReply Direct Link To This Post Topic: Any Yanmar experts?
    Posted: 19 Feb 2022 at 7:31am
I know off topic but looking at a Gehl Skidloader with a bad 3TNV88 BKMS engine.  Have a lead on a good 3TNV88 BKGWL.  Does anyone know how easy of a swap this would be or what is different between the two engines.  Been looking online and cannot really seam to find anything other than what it was used in.  Thanks
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2022 at 11:07am
Not an expert by any means, but the 3TNV88 is the model, and the rest is likely accessories to fit it into a particular application, is what my guesstimation is. If this is the case, you may need to strip both down to the long block transferring parts as needed. Again, just my hunch. I would look closely at both engines and note differences. Once thing to consider though, is the crankshaft may be different from one application to the other, for drive fitment, but I doubt it.
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2022 at 1:55pm
 Just so one isn't for generator with a tapered shaft
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2022 at 4:54pm
I would ask the guy to get a photo of the bell housing and end of crank shaft.. Also the name plate on the motor.. They appear to have an industrial , farm, marine, stationary versions of all their motors... Most are rated HP at 2800 or 3000 RPM.. but i did see a marine version that was 1800 rpm..... The radiator / fan/ muffler / air cleaner can be part of the "package" or mounted separate to the vehicle.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2022 at 6:49pm
Hoye Tractor may be able to answer your questions.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Greg(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2022 at 7:47pm
The replacement motor is used in small articulated loaders.   I have some photos and will try to get comparison
