WD Loader Live Hydraulics
OwlCreekFarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OwlCreekFarm Quote  Post ReplyReply Direct Link To This Post Topic: WD Loader Live Hydraulics
    Posted: 05 Feb 2022 at 8:41pm
I’ve read some old posts about mounting a hydraulic pump on the crank pulley or using a double-groove to run a belt pulley. Does anyone know of a resource for a kit or any guidance on doing this?
Thanks a ton!
1963D17 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1963D17 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2022 at 11:10pm
I have a WD45 with a model 400 or 500 loader. Don't remember. It has the factory loader pump kit installed. It mounts under the radiator and drives off the front of the crankshaft. You can see a picture of the set up in the AGCo online parts book. Look under agcoallis, material handling, A-C farm loaders. It should have been factory on all WD/WD45's. Works good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote OwlCreekFarm Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2022 at 7:05am
Awesome! Thank you!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2022 at 7:45am
I believe Alex from A&W makes a kit to do this.  Includes a new pump, drive hub, mounting bracket and a drive disc that you must weld into the front of the crankshaft pulley. For gas engines only.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2022 at 8:21am
The WD, WD-45 hydraulics/they are hi pressure,  are considered live using the hand clutch.
We had a Stan Hoist, on our '53 WD, it worked well, I loaded a lot of manure with it.
 Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote OwlCreekFarm Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2022 at 8:39am
Dr: would you happen to have a website or contact for A&W? Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2022 at 8:47am
read this..........
Cut and paste from internet........
Need a new or used Allis part that I don't have listed? Call us or you are always welcome to stop in and pick up new or used parts for your Allis equipment at our business location, A&W Tractor LLC, 12802 Wiskow Road, Cecil, WI 54111.
Please ask if you have any questions or call nine20 5nine8 1two87.  I ship within the US only. Payment is due 3 days after auction end. Happy Tractoring from A&W Tractor LLC, specializing in Allis-Chalmers!
Edited by steve(ill) - 06 Feb 2022 at 8:55am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2022 at 8:52am
Dave76 View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave76 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2022 at 8:56am
Here is Alex’s phone number from A and W, 920-598-1287
Post Options Post Options   Thanks (0) Thanks(0)   Quote OwlCreekFarm Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2022 at 9:17am
You all rock!
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2022 at 11:11am
That is for a kit for a D!7 and not a WD.
This what the WD looks like
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2022 at 11:14am
Here is the crank pulley.
Post Options Post Options   Thanks (0) Thanks(0)   Quote OwlCreekFarm Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2022 at 12:51pm
That’s a D17 in the photos, right? Maybe I could do the same and use the D17 kit?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2022 at 2:42pm
No. You cannot use any D-series front pump drives.  It has to be the welded in drive disc and mounting bracket and a pump and drive hub all specfic to a WC/WD/WD45.  There is just enough room. Kinda like 5 gallons of poo in a 4 1/2 gallon pail.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2022 at 4:52pm
Figures 12, 13 and 14 in my post is what is needed for the WD. The earlier posts are for D series only as Dr Allis stated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote OwlCreekFarm Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2022 at 7:11pm
Gotcha! Now just need to locate one specific to the WD!
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2022 at 8:48pm
My 460 loader for my 160 is driven off the crank pulley like in the above picture. Loader is self contained and doesn’t use any hydraulics off the tractor.
pirlbeck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pirlbeck Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2022 at 9:41pm
I put a live pump setup on a WD I owned years ago. If I remember correctly, I purchased the weld in drive plate and the drive lug from Agco and used either a used combine hydraulic pump or a pump from a hydraulic supply house. One thing I do remember for sure, is that I had to swap out the front bolster casting, as they way it was made did not allow enough room for the hydraulic pump. I know I found a used bolster that was not cast back towards the engine as far and it had a lot more open area in front of the crankshaft pulley.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2022 at 5:37am
No where in the WC/WD/WD45 front pump installation instructions does is tell you there might be a chance that the front steering support might have to be swapped out for a different one. The reason you had to was because you weren't using the correct pump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote pirlbeck Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2022 at 6:58am
You are more than likely correct, I just threw it out there in case someone runs into clearance issues. If I remember correctly, the very top of the casting had a lip on it that extended back to the bottom of the radiator/grill area and was all hollow underneath it.  Prior to this I did not even realize that there were different bolster casting used.
This page was generated in 0.053 seconds.
