difference between 190xt- 200
ribsplitter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ribsplitter Quote  Post ReplyReply Direct Link To This Post Topic: difference between 190xt- 200
    Posted: 22 Sep 2010 at 6:31pm
what are the differences between a 190 xt and a 200?
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2010 at 8:17pm
Later 190xt had wider finals than earlier and 4 pinion differential but most XT diesels were changed over on a recall to wider finals. The 200 had even wider finals. The 200 had a MarkII? 2900 engine with a better cooling fan and other improvements. Grill is different. Some other minor changes in hydraulics. Fuel gage is in the tank and not on the dash at least on some anyway. Not a whole lot of differences really.
Wink
I am a Russian Bot
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2010 at 9:13pm
200 was first to have factory AC cab, 190 XT cabs were aftermarket
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2010 at 9:17pm
I believe the 200 had different 3 point geometry and could lift about 50% more?...also thought I've seen some comments about the 200 having a "gated" power director lever on the side console that caused some PD wear problems if not adjusted correctly.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2010 at 9:18pm
200 Had a different turbo and resonator, and a slower turning  blade fan for better cooling.  To name a few.  Right from Norm's boodk.
7 blade fan
Lester View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lester Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2010 at 6:23am
The 200 also had 2 oil filters .
gcalent View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gcalent Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2010 at 8:55am
later 200`s had the better disc type brakes that held better and lasted longer
Pullin With AC
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2010 at 9:00am
The 200 is ten more than the 190.
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2010 at 9:00am
The 3pt had the cylinders mounted below the axle line on the axle housings versus above, giving better geometry.  7000 was the same way.  Also, didn't the 200 have wider gears in the transmission?
Hurst
1979 Allis Chalmers 7000
5800 Hours
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2010 at 10:12am
the 200 had larger axles, also offered long axles. the gated power director was part of the cost reduced tractors I think, as early ones had the same lever as a 190. the 200 should actually dyno about 105hp also since they were never tested, and based on the XT test. the injection pump for a 200 is set for higher fuel delivery than an XT, although later XT's were set to a higher spec than the early tractors, the 200 is still a little hotter.
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2010 at 10:30am
 Axles are the same  diameter  from later 190 to 7000, 3 1/4 inch.
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2010 at 8:43pm
Did any xt's come out with the hyd. pto clutch.
Leon B MO
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2010 at 8:51pm
Is it just me or does that cab on the 200 look somewhat like the one on a 7000 series?
                                                         VS
Edited by AllisChalmers37 - 23 Sep 2010 at 8:51pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2010 at 9:11pm
yes, the cabs do seem similar. the side windows are drilled with bolts going through the glass to attach to the metal hinge. definitely a family connection.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2010 at 9:18pm
Didn't the 200 come with 38" rubber as standard whereas the standard for the 190 was 34"?  Also didn't the 200 have the two speed pto option where the 190 was either/or?
ALLIS EXPRESS!
This year:
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2010 at 5:30am
Late 190's had the optional dual speed PTO.
Wink
I am a Russian Bot
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2010 at 5:31am
Leon B MO
Yes, from the beginning it was an option. My Dad's gas XT is a 1965 with this option.
Wink
I am a Russian Bot
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2010 at 5:33am
Both Cabs are designed and built by Allis.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lester Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2010 at 6:25am
A very low % of 200s came with 38s.
