need gleaner help ASAP
clint View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote clint Quote  Post ReplyReply Direct Link To This Post Topic: need gleaner help ASAP
    Posted: 22 Sep 2010 at 8:32am
first- how do i wire the reel speed for a 316 head to an m2
second, how do i remove the cyl bars- i might get a new set- is it metric? are the backs welded in and i just turn the outside bolt?
Our farms stuff: agco gt55, AA 8775, 8765, 6080, 185, 180, 175, 170, d15, d14, d14, wd, wd, wd, g, F3, L3, R62
NEJim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEJim Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2010 at 8:50am
I'd have to look at the reel wiring but the cyl bars are just bolted on.  There is a nut and lockwasher on the back.  Make sure when you replace them you put them on in pairs with one across form the other.
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2010 at 8:43pm
Depending on the condition of the bolt heads on the cylinder bars you may just remove them with a torch just be careful not to burn the combine up.
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2010 at 9:40pm
Ive always done the bars by removing the panel on top of the throat.  I dont know for sure how the wiring is on the header, but all you really need to change is to run a wire from the reel speed button to the hydraulic reel control on the header.  Good luck.
Don M SEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don M SEIA Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2010 at 9:43pm
I think there can be balance weights on the inside, been a long time since I did one.  Don
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2010 at 2:26pm
header is wired with either a dual pole dual throw switch that is cross wired like a actuator on a hay baler with electric motor for actuator.  The wiring diagram is in the back of op man for factory wiring.
9675 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 9675 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2010 at 3:51pm
Wires should be in harness by return to cylinder plugs should match head.
michaelwis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2010 at 4:25pm
Use a torch .. have  a garden hose ready ..BETTER YET WET IT DOWN BEFORE ..  make sure you turn  the bars a 180  as the back ..(leading edge ) is not worn unless  someone else turned them ..
Worthington  ag parts ..may have a set ..not turned
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60   GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
