D15 industrial shuttle clutch
jbc1179 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbc1179 Quote  Post ReplyReply Direct Link To This Post Topic: D15 industrial shuttle clutch
    Posted: 03 Jan 2022 at 1:35pm
Need to rebuild the shuttle clutch on my D15 industrial (loader/backhoe).
Does anyone have a point of contact where to buy a service manual for it or is it the same as the AG D15 service manual.
Is the shuttle clutch similar to the power director?
Also, what is is good resource for shuttle clutch parts, disks etc..
And any advice on tackling this project?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2022 at 8:58pm
The shuttle clutch itself is identical to the power director clutch. What is wrong with yours ?? If it is slipping, I'd imagine it just needs shims moved around, not rebuilt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbc1179 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2022 at 9:11pm
Well to tell you the true th I’m not all to sure. I don’t know much about the PD. This is the situation. With the PD lever I can slowly go forward or reverse in all gears. But I can only do that at a low idle, any faster and the tractor stops. I’m thinking the transmission clutch is perhaps the issue and will fix the problem? Or is it a shim issue in the PD?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbc1179 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2022 at 9:13pm
The engine runs very well with no issues.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2022 at 4:51am
First thing to check is the set scrrew, at the bottom of the "big stick"...Wink
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2022 at 5:54am
Check foot clutch first dos it have free play
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2022 at 6:27am
If the long shuttle clutch lever stays "locked" into reverse or forward, that clutch can't hardly be slipping. The throw on that lever is about 30+ inches front to back.  It has to have a good crisp snap to it when you pop it into neutral. If not, it may need shimming to restore proper snap.
