Allis Chalmers B Wiring Harness
cfciii03 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cfciii03 Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers B Wiring Harness
    Posted: 20 Dec 2021 at 7:18pm
How is the wiring harness routed around the carburetor ? Are there clips next to the engine block ? Is the coil wire really wound under the thermostat housing ? Any pictures of all of this ?
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2021 at 7:52pm
I have a CA that is very similar.  There are 3 wires that come out under the gas tank:  1 for the generator, one for the headlights and one for the distributor.  They are in a piece of loom that runs behind the carb and gets secured in place with a clip that runs up from the back bolt on the generator mounting.  From there, the wires separate: 1 goes to the generator, one goes up over the rad to connect the headlights.  The last one goes around the thermostat housing and hooks up to the distributor.
Hope this helps, unfortunately I do not have any pictures.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cfciii03 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2021 at 7:25am
Dear DSeries4,
Many thanks - hthat helps a lot.
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2021 at 8:18am
I have four wires on mine. two to the generator, battery and field, ignition, and lights. One clip on the generator mount and another on the bottom of the thermostat housing that the ignition wire goes through.
http://lonsallischalmers.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2021 at 11:49am
On the B/C/CA, the wiring system ran out from the bottom of the instrument panel, under the tool box, behind the air cleaner (under the relief in the air cleaner bracket) behind the Carburetor to a harness bracket mounted on the Generator bracket to the block, up under the Thermostat housing and around the bend to the Mag or Distributor. With a 6V system, it usually was 4 wires as Lonn mentioned. But, like anything else mass produced, there were variations that's fir' sure!   HTH
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote cfciii03 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2021 at 7:31am
many thanks for the assistance.
