sand blast or wire wheel
D17 owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17 owner Quote  Post ReplyReply Direct Link To This Post Topic: sand blast or wire wheel
    Posted: 20 Sep 2010 at 10:15pm
Hi I am just woundering how many people use a wire wheel on a grinder over sand blasting? I have done both. I have painted a farmall H that a guy  did not want to put the money in for sand blasting so I wire wheeled it. It turned out really good. One thing that helped tho is there was NO paint on it so I did not have to worry about seen old paint under the new paint if you know what I mean.  Sand blasting is nice for the hard to get places. So I ask agian sand blast or wire wheel? Eric
Jamie (KY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jamie (KY) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2010 at 10:35pm
I wire wheel everything that I can with two different levels of wheels. The course wheel for the bad stuff and the finer wheel for easy stuff. Then I go to the sandblast booth that I built and do the hard to reach stuff. The more I get done before sandblasting, the better. The booth is hot and needless to say... pretty nasty.
Just when I thought I was finishing my "honey-do-list", she turned the page!!!
allallis2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allallis2 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2010 at 1:00pm
I try to wire wheel what I can just because I dont want the sand to get into places like bushings or brakes.
1955 G,1938 wc unstyled, 1938 A 1938 B, 1949 G
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2010 at 1:02pm
I use one of those scuffing pad attachment for the angle grinder, it works very good and doesn't deform the metal any.
Charlie
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2010 at 1:04pm
A person that sand blast a tractor that is not taken apart frist should be SHOT!!! LOL
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2010 at 1:07pm
I bought one of those air-powered needle scalers ..it works great for getting into tight places and thick paint.  Gotta wear eye & ear protection when using !
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2010 at 1:47pm
Fred - sporting any old bullet wounds????? LMAO!  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2010 at 2:08pm
I'm gonna agree with Fred.  I don't see how you can keep the  blast material from getting everywhere, so looks like a dismantle is in order.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2010 at 2:32pm
If it's a part that can come off the tractor then it gets blasted, if not then it's sand, scrape, wire brush, tooth brush, oven cleaner, scotch brite and any other way to get it ready.
Edited by Stan IL&TN - 21 Sep 2010 at 2:33pm
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2010 at 2:41pm
Had a guy that blasted his  tractor and then painted it. After all the seals started leaking and he ask me about fixing some leaks ,he says do not mess up the paint where you have to take it apart I laughed at him,he did not think it was funny,he did not use any primer you could roll the paint off right in to a ball.I would not work on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jamie (KY) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2010 at 3:06pm
That'd be a good lesson learned for the fella.
My tractor is not perfect, but I did a whole lot of research and I learned a lot since it was my first tractor. I'm interested in doing another and taking a little more time in some areas. I look back now and there's a lot of things that I would have changed. This guy sure learned an expensive lesson.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2010 at 4:08pm
I wire wheel. That doesn't mean I like it. LOL
I have wanted to throw that thing so many times it aint funny.
Dave in PA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in PA Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2010 at 4:28pm
Fred, you need to WORK WITH PEOPLE!  LOL  That is like putting the cart in front of the horse!
Dave in PA
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2010 at 4:56pm
i have mostly did the wire wheel on everything.  Sandblast only small stuff.  Gives you lots of quality time with your hardware.
I mostly use the 4" angle grinder with cup wheel and last year I got an electric die grinder with small wire wheel that is the berries for tight spots.
Use good mask.  Using electrolysis to get the tough stuff and complex items then wire wheel really works good on moderate size parts.
Edited by Rick of HopeIN - 21 Sep 2010 at 5:07pm
JH Buck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JH Buck Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2010 at 5:37pm
I have restored seven Allis Tractors all tin blasted other parts wire brush
Doug northern IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doug northern IL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2010 at 6:39pm
Im with stan whatever it takes. Ive used a tooth brush before.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2010 at 6:54pm
I can't believe Electrolysis was only mentioned once!!! I got the boss's son to sandblast my round spoked WC wheels and I did the frame rails but everything else but the differential housing(mostly wire wheel) was cleaned with the batter charger and a lawnmower blade, just add water.
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17 owner Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2010 at 8:39pm
 A guy at work told that to me today I am going to try them this weakend. Thanks for all the posts and info guys. Just for the book (because I dont want to get shot) I have never sandblasted a tractor complete for my own use anyway. At work I sandblasted a grader and two loaders all complete. Spent more time taping and cuting 1/4 plywood for the windows. My first project with glass was on the grader I just used cardboard and said to myself thats good I will just becalful when blasting well I took a window out, and it was the grader I ran at the time. Got new glass and lesson leaned.  Eric
Tim in arkansas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim in arkansas Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2010 at 8:58pm
I used a wire wheel on my model B it took  me about 15 days  working on it weekends and nights I did the whole  tractor that way
Allis Chalmers fan from Arkansas
Allen Dilg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allen Dilg Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2010 at 10:18pm
  I don't think we have restored ANY tractors without sandblasting.  do any mechanical first, replace gaskets/seals that leak, scrape dried grease, remove sheetmetal, tape plug protect as needed,pressure wash if needed, remove wheels  Never blast directly at seals or any openings.  Takes less than 4hrs for carcass about 3 for rest of parts, when done the surface is sanitary for primer.   Thought   all tractors look the same after sandblasting!!!
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2010 at 7:58am
I am with Charlie.  I just kick back and let the stuff bubble in the tank.  Just finished suspending the D 15 back weights in the tank.  Man what a mess - they had umpteen thick coats slopped on with a brush.
Bob-Maine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob-Maine Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2010 at 9:04am
I'm close to making this decision on my G. Plan is to roll the chassis outside with the engine on her, take off the wheels (which are finsihed), cover all openings with duct tape, pressure wash, then sand blast carefully. No disrespect, Fred, but I have seen Alan Dilg's finsihed products and lean toward his method. At the same time, I make a pretty big target and figure you won't miss me with the first round ;>). Bob@allisdowneast
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2010 at 11:15am
I have sandblasted the tin and the bare frame/engine on several rehabs with great results. Apply lots of grease around the seals and plug the openings (I like oil soaked rags) 1st. The grease does a good job protecting the seals and the oil soaked rags stops most of the sand from getting into the openings.
Dave Richards (WV) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Richards (WV) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2010 at 4:59pm
Remember the old adage.  What doesn't kill us, usually succeeds on the second attempt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2010 at 5:22pm
I sand blast. One needs to use some common sense and properly prepare whatever you are blasting. I don't blast near seals. I also cover any seals with duct tape and pack any other openings with grease before covering.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2010 at 6:05pm
 I have a few tractors that i wire wheeled years ago. and they looked good for some time. But now the paint isn't sticking to them very well anymore. Now i snadblast everything. I figure if im going to restore a tractor i will do it right the first time. I completly dissasmble it sandblast and paint everything in peices.I let the paint dry for about a week and then reassemble with new gaskets and seals and usually all new bearings. I restored a ZB Moline like this 10 years ago and it still looks as good now as it did when i restored it
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2010 at 6:32pm
I wanted to paint my D-10 because it was rather rusty, also it was very dirty. I used oven cleaner. Sprayed it on let set and wash off with scrub brush and water, tooth brush in tight places.
Dusty
